05-07-2012, 06:25 PM
#16
I'm Your Huckleberry
Wires on Fire
Originally Posted by jb64
BT & Doc,
I mean it, you both really helped with the other unit, its ready for freon. I was having brain problems believing 2.5 mfd difference was going to double the run current, I was way wrong.
I can be reached by dialing 911 on your telephone. Ask for the fire department.
Thanks.
05-07-2012, 06:29 PM
#17
Wires on Fire
BT,
I didn't want to say it, sometimes tradesmen get mad, nevermind, all ac motors are "3-phase", a cap is used to throw off one of the phases to make a 3rd.
05-07-2012, 06:37 PM
#18
An old Tradesmen
Wires on Fire
The sq d outside, are probably 60 amp disconnect, not breakers. I use them, and it says on the package they come in. Not an over current protection device, disconnect means only(Or something to that wording).
If you garage regularly exceeds 104°, then you might want to get other breakers. but before doing so, I would check how warm/hot they get while its that hot inside.
#19
Wires on Fire
Ok this is good, Never set your analog meter to ohms when measuring 480vac
05-07-2012, 06:45 PM
#20
Wires on Fire
first, not disconnects, breakers outside. It even is labeled 40C, I doubt disconnects have a temp rating. Others have been surprised by this fact too.
#21
An old Tradesmen
Wires on Fire
They tend not to do well when you do that. Some of them have a good fuse that will pen before the meter burns up. Some don't.
05-07-2012, 06:50 PM
#22
An old Tradesmen
Wires on Fire
Does it look like this disconnect.
http://www.google.com/products/catal...d=0CL4BEPMCMAA
05-07-2012, 06:52 PM
#23
Wires on Fire
Back to ohms on 480, meter blew up, the shock wave knocked me down, no hearing, no vision for 30 secs, don't do that
05-07-2012, 06:53 PM
#24
Wires on Fire
exactly
05-07-2012, 06:54 PM
#25
An old Tradesmen
Wires on Fire
exactly
Thats not a breaker. Its a disconnect switch only.
05-07-2012, 06:56 PM
#26
Wires on Fire
911 also has EMS services available. Sorry, I can't help myself. Professional, pff.
Alright, I won't reply on this thread any longer, I'm about to have a brain aneurysm.
Thanks.
The Following User Says Thank You to Doc Holliday For This Useful Post:
05-07-2012, 06:57 PM
#27
Wires on Fire
I mean BT thats exactly what i got
05-07-2012, 07:00 PM
#28
Wires on Fire
Doc,
Lighten up dude, I did that in '85. Now I only burn up 240 or less :p
#29
An old Tradesmen
Wires on Fire
Ah. I guess doc's is rubbing of on me. ROFL
The Following User Says Thank You to beenthere For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
