Old 01-01-2010, 09:03 PM   #1
which wires do in touch to bypass the stat to test a furnace?
I know if person jumps 2 furnace wires at the stat that the furnace will heat. Can someone tell me which 2 wires I need to jump in order to run this test?
thanks
brokenhammer is offline   Reply With Quote
Old 01-01-2010, 10:06 PM   #2
An old Tradesmen
Generally the ones on the R and W terminals.
Of course, if its not a problem with the stat. Then the furnace still won't work.
Old 01-01-2010, 10:22 PM   #3
Thanks for the response. It looks like it's the furnace.
Old 01-01-2010, 10:30 PM   #4
An old Tradesmen
its very very very seldom the thermostat when its a no heat situation.
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Honeywell TrueSteam Humidifier Opinions/Experience dgbehrends HVAC 239 01-16-2012 04:08 PM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 04:45 PM
Furnace Problems? Part 2 MCSE HVAC 9 11-30-2006 10:25 PM
