Which Wires Do I Unplug On Thermostat To Disable Electric Heat Strips? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-02-2012, 11:09 PM   #1
Which wires do I unplug on thermostat to disable electric heat strips?
I have a Lennox 3.5 ton Heat Pump with Honeywell TH3210D1004 thermostat, 2 heat / 1 cool with 10 KwH heat strip in 2500 sq ft house
I want to disable the heat strips because I live in North Carolina and think the heat pump can keep up fine with the house by itself.
I set the temperature to 61 when sleeping, and 66 when I'm home.
I'm ok with it taking longer to heatup the 5 degrees with just the heat pump because it's still more efficient than the heat strips kicking in to speed up the heating.
1. Which wires do I remove in the picture? The jumper that connects E to Aux, the E wire, and the wire going to aux?
2. If I do that, will it still go into aux for defrost mode?
3. Do I want higher or lower # of cycles per hour in order to save money/energy use for the aux/emergency heat setting? Or does it not matter because the COP is 1.0 regardless. I have Cycles set to 3 for compressor
Thank you very much in advance
mordak is offline   Reply With Quote
Old 11-02-2012, 11:51 PM   #2
Rewards Points: 6,652
You would be better to get rid of that thermostat and get one that will properly work with your unit, and allow better setting of when it may or may not need the heat strips.
Old 11-02-2012, 11:56 PM   #3
Any suggestions for 1 thats under $90-100?
In the meantime though, any idea on my other questions?
Old 11-03-2012, 09:32 AM   #4
There are plenty of Honeywell's around that range. But if you really want a thermostat that can be tweaked better, you are going to have to spend more than $100.
Old 11-03-2012, 09:40 AM   #5
I disconnected the white wire in the picture that goes to Aux, and left the jumper between Aux/E connected.
It's 42 degrees outside, thermostat is reading 65, I bumped it up to 68.
The system has been running for 2.5 hours currently and the thermostat is still reading 65.
The air from my register is coming out at 88.5 degrees with no heat strips
Is that normal without heat strips?
I'm ok if it takes longer to heatup with just the heatpump because it's more cost friendly than using the heat strips
Old 11-03-2012, 10:21 AM   #6
It really depends on how efficient the furnace and heat pump are.
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 04:50 PM
reliable thermostat for electric baseboard heat grandmeme Electrical 6 11-19-2010 07:57 AM
Which honeywell thermostat should I buy for my Carrier heat pump? mannypp HVAC 29 01-30-2010 02:21 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 12:04 AM
