Wireless Thermostat Question - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 04:27 PM   #16
Rewards Points: 590
Here's the picture with the other cover removed. Can I use the 3m stat? I do not see the c wire a lot of people talk about in reviews.
nikeman is offline   Reply With Quote
Old 04-22-2012, 04:36 PM   #17
AKA HVACTECHFW
Rewards Points: 1,208
Well, I was hoping for other terminals there..... You will need at least 6 wires to the thermostat. In order to know for sure you will have to open up the indoor equipment and view what wires are on which terminals in the equipment.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 04-22-2012, 04:38 PM   #18
Rewards Points: 590
are you saying to take that last panel off also and look behind it? I see 6 different color wires although I have no clue what they mean..
Old 04-22-2012, 04:42 PM   #19
AKA HVACTECHFW
NO.
DO you have a split system (furnace or air handler inside and a heat pump or air conditioner outside)?
DO you have a package unit that is all outside that your ducts connect to?
Pictures or model numbers are helpful.
Depending on which type of system you have you will need to locate the low voltage wires in the indoor/outdoor unit from the thermostat to determine if you can and how to wire a replacement thermostat.
IT IS WHAT IT IS
Old 04-22-2012, 04:50 PM   #20
Rewards Points: 590
I hope this helps. It's pouring down rain right now. It also says heat pump right on the unit, go figure. Lol
Old 04-22-2012, 05:06 PM   #21
AKA HVACTECHFW
ok, that is part of a split system. You need to locate the indoor unit.
IT IS WHAT IT IS
Old 04-22-2012, 05:09 PM   #22
Rewards Points: 590
What do I look for? I do have 2 air filters that I change every month and I obviously know where the control unit as well as the big outside unit but other then that, I have no clue.
Old 04-22-2012, 05:15 PM   #23
AKA HVACTECHFW
attic? crawlspace? Basement?
Call a PRO?
IT IS WHAT IT IS
Old 04-22-2012, 05:20 PM   #24
Rewards Points: 590
Its in the attic (if you want to call it that) upstairs. I can't get to it right now because the ladder is outside and its still raining. The attic is just big enough for duct work and that unit so its pretty tight up there.
What does this mean though? If I am able to get up there and get a closer look what exactly should I look for? It actually looks exactly like your picture only on its side... Can you find what you need to know online? If not I will get my self up there one day this week and take a good look... I have never been up there before so I guess I need to check things out eventually anyway
Old 04-22-2012, 05:26 PM   #25
AKA HVACTECHFW
reviewing your current thermostat wiring...... We don't know for sure what X is for... It should be C, but I like to make sure. Also, I'm not sure why you have 2 wires from the wall connected to W2.
By gaining access to the indoor unit you can see what terminals the color of wire is connected to inside the air handler.
IT IS WHAT IT IS
Old 04-22-2012, 06:08 PM   #26
Rewards Points: 590
I just cant get to it tonight in the rain... I was able to get the model number off the unit though...
Its a RUUD
UBHA-17J11NUGA
There is a wire diagram above the sticker with the model number but its to high up and I can even get the camera phone close enough to get a readable picture...
Old 04-22-2012, 08:26 PM   #27
Rewards Points: 590
I found this posted on another forum by a guy who has the same star as I do. Does this help?
Honeywell
O c/o valve heat
X common
G fan
R power
E them heat
W2 aux
Y compressor
Old 04-22-2012, 08:28 PM   #28
AKA HVACTECHFW
i knew all that already. In order to VERIFY your wiring you MUST check inside the indoor unit. However, if you want to just try then go ahead.
IT IS WHAT IT IS
Old 04-22-2012, 08:50 PM   #29
Rewards Points: 590
I will get up there one day this week and check it out.
Old 04-23-2012, 06:51 PM   #30
Rewards Points: 590
This is what's behind the panel. No idea what I'm looking at
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Thermostat Question haninja HVAC 8 07-26-2011 06:19 AM
Question about wireless router close to TV Jessidog Home Theater 4 07-22-2011 07:04 AM
Installing a wireless thermostat BPH HVAC 4 05-27-2009 12:37 PM
Thermostat question ctown HVAC 7 12-05-2006 03:46 PM
