Wire Size ..... - HVAC - DIY Chatroom Home Improvement Forum
Old 07-07-2014, 07:04 PM   #1
Rewards Points: 236
wire size .....
... for my compressor ? 240v 15a. thanx
Fix'n it is offline   Reply With Quote
Old 07-07-2014, 08:01 PM   #2
Rewards Points: 907
#10 or #8 wire.
Bitters is offline   Reply With Quote
Old 07-07-2014, 09:03 PM   #3
Rewards Points: 3,256
Does your compressor list the circuit and breaker/fuse size on the name plate?
zappa is offline   Reply With Quote
Old 07-07-2014, 09:39 PM   #4
Rewards Points: 236
thanx, guys. silly me, i didn't think to go look at the wire in the panel. it is 10g.
Old 07-07-2014, 11:50 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
15A? 10g/8g? Really? 12g is rated for 20A
Old 07-08-2014, 12:11 AM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,850
Yes.... I'm with Dawg... I'd run 12, but considering its not continuos, could you not run 14.????
Happy to be corrected.....
MTN REMODEL LLC is offline   Reply With Quote
Old 07-08-2014, 04:32 AM   #7
An old Tradesmen
Rewards Points: 7,372
Data plate on condenser will list the min wire size that can be used.
Old 07-08-2014, 05:52 AM   #8
Rewards Points: 1,216
Data plate or installation instructions that were provided with the unit if it is new. Specification sheet.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 07-08-2014, 07:25 AM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 2,276
#12 probably. Because thermostatic expansion valves make it harder to start, #14 is rare and only used on a few 1.5 ton units in my experience.
Old 07-08-2014, 08:16 PM   #10
Rewards Points: 236
at what # does wire turn from solid to stranded ? my 10 is stranded.
since i only need about 6'. i am just going to get that off the roll at HD.
Old 07-08-2014, 09:59 PM   #11
An old Tradesmen
I've seen stranded 16 gauge.
Can probably get a pre made whip, for less then cut off the roll.
The Following User Says Thank You to beenthere For This Useful Post:
jbfan (07-08-2014)
Digitial Timer in 3 Gang box with (2) 3way switches and 1 single pole..confused. BCS Electrical 33 03-20-2016 11:30 PM
New Sub Panel Wire Size? johnsas Electrical 4 08-29-2012 11:20 AM
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 09:38 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
