-   -   wire new out door ac fan motor (http://www.diychatroom.com/f17/wire-new-out-door-ac-fan-motor-177749/)
denn 04-21-2013 02:04 PM
Replacing ge fan motor with ao smith fe1026sc motor.Ge motor had three wires and used a dual capacitor. New motor has 4 wires brown , brown and white stripe, black, white. It came with a new fan capacitor. It appears the brown & brown and white will go to new capacitor if that is correct I don't understand how it gets power. The original capacitor I think will keep the blue compressor wire on the herm terminal, the fan terminal will be empty. Black of old motor went to circuit board I guess this motors black will go to same place (??) and white to ?????
The old motor third wire Yellow went to capacitor common.
Any help will be appreciated.
Dennis
Houston204 04-21-2013 05:22 PM
http://i151.photobucket.com/albums/s...otorWiring.jpg
Connect the black wire to the defrost control like the old motor was wired.
I would cut the 4 small bolts on the shaft side of the motor to allow the blade to operate closer to the motor if they are not used for mounting.
denn 04-21-2013 06:27 PM
Thanks - Just to be sure. Your replacement motor diagram shows white going to right side of contactor. The original motor wire (yellow) was going to common of dual capacitor. Then another from common to right side of contactor. Maybe for ease of wiring if motor was replaced?? Can I wire white
motor wire to the common in the same way.
Thanks for your help
Dennis
Houston204 04-21-2013 06:44 PM
Either way. The yellow wire from the contactor to the capacitor common makes either choice the same electrically.
I wire it to the contactor if there is an available spot.
Sounds like you are working on a Carrier/ Bryant unit.
denn 04-21-2013 07:09 PM
Yes it is a carrier unit - original motor is a ge hc39ge237 its getting noisy
and I want to give my neighbors a break. You have been most helpful.
I am going to tackle this in the am. Need to cut shaft and will cuts bolts as you suggested.
Regards,
Dennis
Houston204 04-21-2013 11:18 PM
Cutting the shaft is rarely required with 2 ton or larger condensers, though it often appears as if it will be necessary. Some older round Carriers units also required this.
Cutting the 4 bolts on the shaft side of the motor is usually required or the blade sits too low in the condenser and does not properly discharge air from the top of the unit.
sammy37 04-22-2013 09:16 AM
When you mention shaft length, remindes me of a post I read somewhere that somebody had their fan motor replaced and the shaft being too long, bored a hole into the top of the compressor! They were inquiring how or what to use to patch the compressor. Lol
Houston204 04-22-2013 12:00 PM
I've seen the shaft rubbing the top of the compressor on a small 1.5 ton unit before.
The customer called back because it was very noisey.
I was amazed that the old tech that installed it could not hear something so noisey.
biggles 04-22-2013 01:44 PM
for others reading this finger measure that space between the blade and the motor ...spritz of WD40 down the shaft grab the area between the motor and shaft "channel locks" and 1/4 turn back and forth....:wink: do not try to slide that blade housing yet :no: full turning old blade and sanding of the old shaft and you good to slide it up
denn 04-23-2013 11:31 AM
Houston 204
Finally quit raining and installed fan motor. I'm not sure rotation is correct
It is turning counter clockwise. Feel some air coming out but that could just be a kick back off the bottom??? I expected a rush of air. any way to tell
by the pitch of the fan blade or some other way.
JScotty 04-23-2013 12:47 PM
Originally Posted by denn (Post 1165607)
Houston 204
Well you can watch it spin, it should be pretty obvious. If it's spinning from the side of the blade that points down to the side that points up, air will go up. But try taking a piece of paper & sitting it on top of the fan grill. If it blows off it's right, if it sucks to the grill it isn't.
If it's not right most generic motor have reversing wires which will be preconnected to each other with spade terminals. (usually orange & yellow on the motors we use) Switch the wires around to make it spin the opposite direction
denn 04-23-2013 01:19 PM
it's obvious now - after you said it. I will change plug as you suggested.
I last question - does it matter what side of run capacitor does the brown
wire and brown and white go. I have brown on left and brown and white
on right as you look at front of capacitor. I think not but ??
You have been a great help.
Dennis
JScotty 04-24-2013 04:44 PM
Dennis
No it doesn't matter, as long as they aren't connected to the same terminal it should work.
denn 04-24-2013 05:56 PM
The fan is installed and running correctly. I learned a lot thanks.
The noise was still there so I disconnected the black fan wire to stop
fan and ran compressor for a few seconds and that is where noise is coming from. Unit is a heat pump and it is blowing cool air so the (transfer switch ???) must be working. The coils have been cleaned. Compressor is 7 years old. I'm not sure if there is any thing I can check. If I place a service
call are there intelligent questions I can ask. I have a feeling that service tech will simply say I need a new compressor. That's okay if it is the real answer. In my case I will need to replace handler also as this is a r22 system.
denn 05-09-2013 02:20 PM
Finally got to source of loud compressor noise. a/c guy working on my neighbors air conditioning did a quick check & removed compressor hold down
bolts. Noise went away. He said bolts not needed - unit not going anywhere
piping will hold it in place. Should I be concerned?
