Wire Colors - HVAC - DIY Chatroom Home Improvement Forum
Old 12-09-2012, 08:37 PM   #1
Rewards Points: 220
wire colors
i had to take my stat loose today, to put up drywall. when i loosened the screws, i noticed the blue wire had broken loose. the furnace was working just fine. so idk if that wire was loose or i had broken it right then.
anyway. green, white, blue, red. what does each wire do ?
Fix'n it is offline   Reply With Quote
Old 12-09-2012, 08:45 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Not colors, terminals but on average it is the color connected to the corresponding terminal.
Terminal/ wire color
G-green wire (fan)
W-white wire (heat)
Y-blue wire (cooling) -had you had a yellow wire that may also (instead of blue) have been used for Y/cooling
R-red wire (24 volts.power)
Many times the blue is used as a common on digital stats but again, you'd have a different color wire, mostly yellow, connected to the Y terminal for cooling.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
plummen (12-10-2012)
Old 12-09-2012, 08:46 PM   #3
Btw, you should turn the breaker to the furnace off before doing any stat wire work. You can blow a fuse or a transformer if you touch that red/power wire live to metal.
Thanks.
Old 12-09-2012, 08:51 PM   #4
Now if you don't have cooling and you do have a digital stat than blue would be on the C terminal/common to power the stat.
Thanks.
Old 12-09-2012, 08:54 PM   #5
Roofmaster
Rewards Points: 2,172
Plan Ahead
You do have a digital camera, or a cell phone with a camera in it, and took a picture or made a sketch of where the wires connected before you disconnected them right?
If the blue one broke, there should be a little wire loop under the screw where it went. Now at least you know where the blue one goes. ;-)
Old 12-09-2012, 09:59 PM   #6
Rewards Points: 220
ok
the red wire. that powers the stat ? my digital stat has batteries. so what does the red wire do here ?
i turned the furnace off with the switch on the side of it.
i did write down the connections. but i didn't need to. as the terminals are labeled.
Old 12-10-2012, 05:12 AM   #7
An old Tradesmen
Rewards Points: 6,516
It brings 24 volts to the stat so when the stat closes one of its switches, 24 volts can be sent to the terminal that provides heating cooling or fan on, as needed.
Old 12-10-2012, 11:16 PM   #8
Rewards Points: 220
thanx. yeah, i thought just that after i logged off yesterday.
Old 12-11-2012, 08:16 AM   #9
Rewards Points: 446
You didn't mention air conditioning so I'll assume you don't have that.
Some digital stats require (or have the option) of a connection back to the furnace that basically is the ground or neutral so the stat can use the power from the furnace's transformer to keep it powered up. This kind of style uses the battery only as a backup incase of a power outage.
old_squid is offline   Reply With Quote
installing a dimmer - wire colors dkcyw Electrical 2 07-04-2012 03:06 AM
Honeywell vision pro, fan always on? and True Steam problem c5sb HVAC 6 06-19-2012 10:08 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Wire colors to a switch jamiedolan Electrical 5 09-14-2008 03:01 PM
