Winter/Summer Setting - HVAC - DIY Chatroom Home Improvement Forum
Old 10-15-2007, 07:51 PM   #1
Rewards Points: 133
Winter/Summer setting
The duct work that comes out of my furnace has a lever on the outside that is marked with a Winter and a Summer position. What is this for? What would happen if, lets say, I would forget to change the setting one season? Just curious.
Thanks.
bucksone is offline   Reply With Quote
Old 10-15-2007, 09:28 PM   #2
Rewards Points: 380
Hi Bucksone,
The lever you are talking about on your ductwork is there to allow air to go around your A/C coil in the heating mode, so that you don't have to push all the hot air generated by your furnace through your A/C coil. It isn't as crucial for heating operation as it is for cooling, however if it is left in the closed position for the winter it could cause a reduction in air flow through the heat exchanger and cause your furnace to go out on high limit.(too much tempurature in the heat exchanger)
It is more crucial in the cooling mode, as it forces all the air through your A/c coil in the ductwork. If you were to have this damper open during the cooling mode(winter setting) you would allow quite a bit of air to bypass your A/C coil possibly causing your A/C unit to freeze up and cause damage to your compressor. You would have poor cooling and poor dehumidification in this position.
Hope that clears it up for you, good luck
Dave
HVACDave is offline   Reply With Quote
Old 10-16-2007, 03:29 AM   #3
Rewards Points: 133
Thanks for the quick reply. I will keep this in mind in the future.
premix joint compound vs setting type ITE Drywall & Plaster 32 03-12-2014 05:04 PM
Setting Pilings For Boat House donwells Building & Construction 3 06-22-2009 12:19 PM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 09:22 AM
setting post straight econdave Building & Construction 5 06-17-2006 01:20 PM
