Window Unit Want Turn On. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-22-2013, 07:23 AM   #1
jburd964's Avatar
Rewards Points: 166
Window unit want turn on.
I have a 220v window unit that was running when pulled and stored in December, I cleaned and re-installed it and now it isn't doing any thing. I have power up to unit thermostat. I also have power to the 3 wires [approximate 14 -16 gauge] connected to the side of compressor.I understand how ac's work but don't know the workings of the electrical portion of unit. Any trouble shooting help would be appreciated.
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 08-22-2013, 02:59 PM   #2
An old Tradesmen
Rewards Points: 7,270
Does anything on it run.
Old 08-22-2013, 03:47 PM   #3
Check the capacitor. If the compressor has power but doesn't run then either the capacitor is bad or the compressor is seized.
Old 08-22-2013, 04:54 PM   #4
jburd964's Avatar
Rewards Points: 166
It doesn't do anything.No hum. No fan. Nothing.
Old 08-22-2013, 06:12 PM   #5
An old Tradesmen
Either the stat is bad, the run cap is bad, or its not getting 240 volts.
Old 08-22-2013, 06:38 PM   #6
Rewards Points: 582
my guess its not getting the required 220 volt...check across both legs for 220...not each leg to ground..ben sr
Old 08-22-2013, 07:29 PM   #7
biggles's Avatar
work on getting just the fan running in FAN setting.verify 230v within the unit control section where the power cord connects
Old 08-23-2013, 01:12 PM   #8
jburd964's Avatar
Rewards Points: 166
Confirmed 220 to selector switch. Found wiring schematic and unit has a dual capacitor. Could it be the probably? How could it be checked?
Old 08-23-2013, 03:54 PM   #9
An old Tradesmen
Use a meter that can read microfarads.
By confirmed 220 volts. the meter actually read 220 volts on its line side and its load side, correct.
Old 08-23-2013, 05:24 PM   #10
jburd964's Avatar
Rewards Points: 166
Some things going on with one of circuit legs in sub panel, voltage is fluctuating.
Old 08-24-2013, 08:22 PM   #11
jburd964's Avatar
Rewards Points: 166
Fixed bad pole in box. But in mean time I had pick up another window unit and was having same problem. Now second unit is working. Haven't gotten a chance to try first unit again. I think it should run also.
Thanks for help..
Tags
air conditioner , electrical , trouble shooting
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Need help w/squealing screeching ac window unit ohiogirl HVAC 1 07-12-2009 06:01 PM
Nasty smell in my Samsung window unit deejohnson HVAC 4 06-15-2009 09:02 PM
Portable A/C unit + Swinging Window alpha202ej HVAC 1 07-18-2008 10:51 AM
Adding Geothermal heat exchanger to window unit richinok HVAC 4 06-23-2008 06:59 PM
