Window Unit Sizin - HVAC - DIY Chatroom Home Improvement Forum
Old 06-04-2015, 10:09 PM   #1
Rewards Points: 91
Window unit sizin
Hi all, I live in Chicago area and have split level home with 5 levels: basement, family room (partially below grade), kitchen/living, bedrooms, and a 13x25 attic room. We've got a single central air unit that does fine on the lower floors, but that attic room is still really warm. That room is also my wife's home office and she works in the afternoon/evening so she's uncomfortable during the summer. It also doubles as a guest bedroom. I was going to get a window air conditioner for that room but can't decide between 8000 BTU and 10000 BTU. Would there be that much of an efficiency or power consumption difference between the two? We are also thinking of doing new furnace/AC in the next year or two so I'm planning to ask the contractor about how to fix this without relying on a window unit.
scottyv81 is offline   Reply With Quote
Old 06-05-2015, 05:17 AM   #2
An old Tradesmen
Rewards Points: 6,086
8,000 should be plenty if your only using it as a supplement to the central A/C.
Too big, and the humidity could get too high.
Old 06-05-2015, 06:11 AM   #3
For a single room I would go with a 5000 BTU unit particularly as it is a supplement . I use a 5500 unit to cool my office bedroom which has a large Apple Power Mac tower computer, a laser printer, a Mac mini, three monitors, and all my network equipment . The room is on the south side of the house (lots of heat lid from the sun) . I don't have central air and this unit is capable of turning the room into a meat locker if I turn it up all the way. 10000 BTU will be over kill and I think 8000 will be was well. I cool my 5 room 1000sq ft downstairs with a 12000 BTU and that is marginally oversized
jimn01 is offline   Reply With Quote
Old 06-06-2015, 07:59 AM   #4
Rewards Points: 91
Thanks for the info, the 10000 is definitely out. Hadn't thought of just using a 5000 though since it's just supplemental. Only thing that would concern me is times when the window unit would be on but the central air would be off since sometimes temp is fine in the rest of the house. I guess that wouldn't be very often though. Jimn01, for reference how big is your office room that you are using the 5000 unit for?
Old 06-06-2015, 01:19 PM   #5
Rewards Points: 42
Before you put in a window shaker, I suggest looking at portable units as well. They are on wheels so it's easier to hide in the closet when it's not needed. They are very easy to setup and look better from outside your house. The catch is that they take up a bit more floor room.
For reference, a typical computer system would generate between 314-1500btu/hr. (including monitors) A person sitting is approx 150-200 btu/hr. The rest is the heat from the environment.
Cheers!
supers05 is online now   Reply With Quote
Old 06-06-2015, 02:33 PM   #6
Rewards Points: 1,989
Or a mini split ! :-)
God bless
Wyr
WyrTwister is offline   Reply With Quote
The Following User Says Thank You to WyrTwister For This Useful Post:
supers05 (06-06-2015)
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
Need help w/squealing screeching ac window unit ohiogirl HVAC 1 07-12-2009 07:01 PM
Nasty smell in my Samsung window unit deejohnson HVAC 4 06-15-2009 10:02 PM
Portable A/C unit + Swinging Window alpha202ej HVAC 1 07-18-2008 11:51 AM
Adding Geothermal heat exchanger to window unit richinok HVAC 4 06-23-2008 07:59 PM
