Window A/c For Wall - HVAC - DIY Chatroom Home Improvement Forum
Old 05-22-2013, 08:21 PM   #1
Rewards Points: 874
Window a/c for wall
We have a small a/c in the wall in our rental apartment but i think it is a window a/c. We need to change it as it is old. It seems there are no wall a/c units out there in that size. Can a window a/c be used in a wall? Thanks
Mstrlucky74 is offline   Reply With Quote
Old 05-22-2013, 08:37 PM   #2
Rewards Points: 616
sure as long as the condenser gets air and it fits the hole and it won't fall out all will be good.....
carmon is offline   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
COLDIRON (05-23-2013)
Old 05-22-2013, 09:06 PM   #3
Rewards Points: 13,716
Got a picture?
Going to be a night mare to try and seal up a window A/C in a wall.
A wall A/C is mounted into a sleave with square edges, a window unit has all kinds of odd ball framing on the bottom of it in most cases.
Old 05-23-2013, 04:39 AM   #4
Rewards Points: 874
Originally Posted by joecaption View Post
Got a picture?
I will take one. Maybe I'm better off getting a wall even if a little more $$$.
Old 05-23-2013, 06:17 AM   #5
lloydb's Avatar
I'd do the wall ac.. take measurements, get as close and you can and use "great stuff" foam in the gaps and then trim it out.
Broken Arrow hvac Broken Arrow Air Conditioning
lloydb is offline   Reply With Quote
General window install questions miamicuse Windows and Doors 9 04-23-2013 08:05 PM
how to deal with a window in a shower MLMIB Kitchen & Bath Remodeling 9 09-12-2012 08:41 AM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
