Window A/c Question - HVAC - DIY Chatroom Home Improvement Forum
Old 06-27-2012, 09:38 AM   #1
waterman1971's Avatar
Rewards Points: 154
Window a/c question
Would it be acceptable to remove the temperature activated valve (plug) on the condensate drain pan. Once this has been removed, I will seal it up so the condensate it still contained. This cost of this part is close to the value of the actual unit itself.
waterman1971 is offline   Reply With Quote
Old 06-27-2012, 09:40 AM   #2
Rewards Points: 14,306
And how is it going to drain if you do that?
Sounds like the pan will just fill up and over flow inside.
Old 06-27-2012, 09:51 AM   #3
Rewards Points: 154
The condensate is used to cool the coil. It is applied to the coil via cupped fan blades that dip into the pan itself. Fairly common on the newer units.
Old 06-27-2012, 10:31 AM   #4
Never saw one of those all the ones I have seen are rubber that you can remove to drain it...but they say to leave it in place because as you say it uses the water to throw on the coil.
Only purpose I could see would be to let the unit drain completely when it was very cold and there was a possibility of freezing.
bill01 is offline   Reply With Quote
Old 06-27-2012, 12:01 PM   #5
Rewards Points: 154
That is correct.The plug is temperature activated.
This unit has heat so perhaps freezing is a valid concern.
My problem is the plug has failed and the cost of the replacement is excessive.
Perhaps a temporary plug is in order.
Old 06-28-2012, 06:11 AM   #6
Rewards Points: 1,216
Why do you want to remove it?
COLDIRON is offline   Reply With Quote
Old 06-28-2012, 07:00 AM   #7
Rewards Points: 154
The plug has failed. I do not want to replace it.
Old 06-28-2012, 07:30 AM   #8
Is this a heat pump or electric resistance? Sorry about the questions.
I would put a temporary plug in there because you want the slinger ring to throw the water against the condenser coil to cool it off. Plus you don't have that dripping all over the place.
I haven't worked with window units in many years so I am a little out of touch with todays technology with small units.
Old 07-03-2012, 12:13 PM   #9
Rewards Points: 154
Thanks for your help, much appreciated. I plugged the hole, so far so good.
Header question - raising door and window RO enoll Building & Construction 10 05-04-2012 04:39 PM
2x6 window header question MoneyPit3 Building & Construction 12 04-02-2012 02:01 PM
window trim question blackestate Windows and Doors 22 09-21-2011 01:38 PM
Replacement window question on install... tidal9 Carpentry 1 08-16-2011 10:18 PM
