Window A/C With No Window - HVAC - DIY Chatroom Home Improvement Forum
Old 01-26-2012, 02:48 PM   #1
Window A/C with no window
I assume this is possible...I want a standard wind A/C unit with no window. Anyone ever done this, and what would I trim it out with...
My humble Man Blog
jasonreck71 is offline   Reply With Quote
Old 01-26-2012, 03:03 PM   #2
frame it in, allow for some mounting brackets.....and a power supply close so you don't need a exstension cord.....
harleyrider is offline   Reply With Quote
The Following User Says Thank You to harleyrider For This Useful Post:
plummen (01-26-2012)
Old 01-26-2012, 03:26 PM   #3
Should I frame it in with green or is regular pine ok...Thanks
My humble Man Blog
Old 01-26-2012, 03:46 PM   #4
Spuce so it won't rot. set it one foot from ceiling ...make sure exterior roof line does not interfere with discharge air.
LIKE THIS
hvac5646 is offline   Reply With Quote
The Following User Says Thank You to hvac5646 For This Useful Post:
dougp23 (01-27-2012)
Old 01-26-2012, 03:51 PM   #5
great pic thanks for the help
My humble Man Blog
Old 01-26-2012, 03:52 PM   #6
SORRY..I MEAN LIKE THIS
Old 01-26-2012, 04:09 PM   #7
An old Tradesmen
Rewards Points: 6,906
Don't get a window A/C. get a thru the wall A/C. It will have its own casement, so it can be serviced later down the road. Without having to pull the framing around it apart.
Old 01-26-2012, 04:09 PM   #8
I wasn't trying to be a sarcastic dink, just gracious
My humble Man Blog
Old 01-26-2012, 04:14 PM   #9
Looks like an easier install than I was planning...Doesnt even cost that much more thanks for the tip
My humble Man Blog
Old 01-26-2012, 05:08 PM   #10
HVAC Tech/ Browns Fan
Put in a mini split www.fujitsugeneral.com/ or others
Tator1076 is offline   Reply With Quote
Old 01-26-2012, 05:44 PM   #11
Hey Been, window units slide out of their cases too.
Old 01-26-2012, 06:04 PM   #12
An old Tradesmen
Some do, many don't. Thru the wall units have their condenser air intake usually further back so the wall doesn't interfere with air movement.
Old 01-26-2012, 06:14 PM   #13
Hvac Pro
yuri's Avatar
Rewards Points: 1,842
Are they quieter? Window shakers are noisy and not my cup of tea. Post a pic of a good one if you can.
Old 01-26-2012, 07:03 PM   #14
I couldn't, but than I never said I could
Old 01-26-2012, 07:10 PM   #15
An old Tradesmen
Depends on the unit, some are made better sound wise then others.
http://www.epinions.com/Air_Conditio...panasonic?sb=1
http://www.rainbowappliance.com/Air-...nditioners-10/
http://www.pcrichard.com/catalog/thu...ntCategoryId=1
Panasonic, and GE are often the quietest ones.
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 02:05 PM
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 06:03 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
