Old 06-28-2009, 07:16 PM   #1
Default window a/c fan motor
I have a whirlpool window unit that is not working. It is 92 in the living room and we are cooking. The motor will run about 5 min and stop. Trying to spin the fan doen't work motor seems stuck. No power fan spins freely. Is this a bad motor or a run capacitor. The fan motor makes a little noise when starting, but stops in just a moment. Any help would be appreciated. Of course this all started on Sat. when the parts places were closed. LOL!! Move to FloridaHAHAHa!!!
Several hours later, fan will not start at all. Loud humming when turned on, no fan. still spins freely with no power. !2,000 Btu. With heat seven years old. Thanks Joe
joevwnut is offline   Reply With Quote
Old 06-28-2009, 08:17 PM   #2
An old Tradesmen
Probably a bad motor.
Depending how old it is, and what size. Better off replacing it.
You don't want to put a lot of money into it. And then the compressor die.
Old 06-28-2009, 08:46 PM   #3
Default window a/c motor
Fan not starting at all now. Loud humming when you turn unit on. !2,000 Btu With heat seven years old. Thanks Joe
Old 06-28-2009, 09:00 PM   #4
Likely time to get a new unit.
If you cant afford one, you can try a different cap, but it could be internal to the motor.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
More On This Topic
In this clip we're going to talk about the proper way to remove and replace an electronic cooling fan. In this step we're going to go over the proper service procedure for removal of the actual cooling fan assembly. And we're going to go over the test... Read More »
My name is Tom Roland and we are at Cottonwood Motor Sports and I am here to tell you about doing service on a Polaris Quad and this is a fairly representative of macho, many of them. Also things that need be looked at are the upper called the tie rod... Read More »
Hi! I'm Chad Smith and I'm a State Certified Journeyman wireman; basically an electrician. I'm here today with expertvillage.com and we are hanging a ceiling fan in this house. Now we've already been through all the steps of shutting the power off... Read More »
How Electric Guitars Work
How Electric Guitars Work by Expert Village
On behalf of Expert Village, my name is Jim Dufresne. I'm here to tell you about acoustic guitar amplification. The electric guitar is amplified differently, as you know, because they use electrode magnetic pickups. And here are the pickups that you're... Read More »
Hello! This is Ross on behalf of the expertvillage.com. Schematics. All right. This is how we communicate. Just like a music. You put notes on piece of paper just like communicate your ideas or you need to communicate our electronic ideas or circuits and... Read More »
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 07:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 10:39 PM
Motor control wiring problem dgr68 Electrical 8 01-04-2009 07:13 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 12:47 PM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 08:30 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
