#1 |
Window AC unit problems, Please assist if you can!
Hello all, this is my first post on these forums.
Well, I have a window ac unit in my house. It is a fairly old house with no central ac, and probobly pretty old wiring. The problem is that every once and a while the AC will "trip", and i have to press the reset button, then the test button (same as the ones on a hair dryer). Sometimes it wont reset for a while and I do not know why. The main issue though, is that I do not know what is causing this. Can anyone tell me what it is? Is there a work-around for it, or some kind of solution. I have it plugged straight into a three prong outlet.(one of the few three pluggers in the house) Any and all help is greatley appreciated. Thank you for your time. Josh- BTW i thought maybe it was surging, bad ground, overheating, but i dont know, and I am not good with home improvment stuff to begin with
#2 |
Contractor
First of all, you should have a dedicated curcuit to the unit. It sounds as if you are plugged in to a GCFI protected circuit, there are multiple reasons for failure here. I would suggest that you consult a local electrician and get it done properly. House fires bite!
| Display Modes | |
| Shrink Film Window Insulation | miserlou | General Discussion | 10 | 11-24-2008 07:19 AM |
| window unit air conditioner help? | greenvorlon | Appliances | 1 | 08-03-2007 12:50 PM |
| Replacing aluminum window with a vinyl one? | Doug Crf | Building & Construction | 2 | 04-23-2007 05:49 AM |
| Window jamb | helpless handyman | Carpentry | 11 | 08-03-2006 01:45 PM |
