Window AC Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 07-03-2013, 03:21 PM   #1
Window AC unit
Just bought a window ac unit and it does not have a drain on the bottom of the pan, can I drill a hole in it to allow the water to escape? It sure makes a lot of pinging noise on the inside of the house. Thanks for any help, Barry
Barry2080 is offline   Reply With Quote
Old 07-03-2013, 03:28 PM   #2
FClef's Avatar
Rewards Points: 160
If it does not have a hole in the bottom of the pan perhaps there is a notch cut out of the casing in the back to allow the unit to drain? Not all window units have drain pan holes in the bottom. If the unit is not draining then be certain that you have a slight pitch to the unit so it can drain. I would not recommend drilling holes... if you even nick a coil it would cost more to fix it than get a new one... depending on the size unit you have.
As far as the pinging is concerned, not sure what that is unless you are hearing water that isn't being drained hitting the fan blades.
Could you provide some pictures of the unit or at least a make and model number?
FClef is offline   Reply With Quote
Old 07-03-2013, 04:55 PM   #3
Rewards Points: 1,214
The unit should be on a slight pitch out not much. With todays units being very efficient most are designed not to drain water or much water .
What happens is the water that comes from the coil drains toward the outside usually through a tube or channel then the fan blade outside is designed with a slinger ring that picks the water up and slings it against the outside coil (the hot one) then it cools the coil off with the water lowering the electric usage. The sound you are hearing is the slinger ring sloshing through the water. It can be annoying. I would try a little more pitch. post back if that don't work.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
Need help w/squealing screeching ac window unit ohiogirl HVAC 1 07-12-2009 07:01 PM
Nasty smell in my Samsung window unit deejohnson HVAC 4 06-15-2009 10:02 PM
Portable A/C unit + Swinging Window alpha202ej HVAC 1 07-18-2008 11:51 AM
Adding Geothermal heat exchanger to window unit richinok HVAC 4 06-23-2008 07:59 PM
