Window AC In Transom Window - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-20-2011, 02:06 AM   #16
Rewards Points: 6,652
del, I explained how to secure the panel to the frame in my previous post. If using Plexiglass, it can be done, but you need to know how to work with plexi to make it work (expensive option, compared to using wood). Using Plexi/Lexan, means more heat can enter the structure, compared to glass & wood.
Old 07-20-2011, 07:54 AM   #17
I mentioned already that the windows are all blacked out with reflective attic insulation material, it is like a cave:
The plexiglass broke recently and I currently have the unit venting out a peice of 1/2" plywood covering the entire transome window, and then all other windows are covered with reflective bubble insulation (like the kind for car windshields) Still sweaty hot after 3 days of non-stop full blast A/C running.
delgriffith is offline   Reply With Quote
Old 08-13-2011, 06:07 PM   #18
To all the doubters, I am now enjoying 73 degrees in my apartment where it was 85 just about 1 hour ago. I've got an insulated plywood enclosure that seals the back half of the AC to the transom window. The 140lb 28,500 BTU AC unit and plywood enclosure are held up to the window which is 10 feet off the floor by scaffolding. A 10 gauge 50ft extension cord allows me to plug the unit into the 220v range outlet. The only part I'm not sure on yet is the drain. The AC unit is designed to blow the condensate water through the condenser coils and outside by scooping it up with the exhaust fan. I can't have it doing that so instead I drilled a hole and mounted a fitting to drain the unit into a floor drain in my apt. It hasn't been humid enough to really test out yet so I'm not sure how that is going to work. It ain't pretty, but at least the place is habitable now, and it falls within the rules of not having AC's hanging outside the windows.
Old 08-13-2011, 06:42 PM   #19
bubbler's Avatar
Rewards Points: 256
Outstanding work Mr MacGuyver!
Seriously good job!
bubbler is offline   Reply With Quote
Transom window repair options (with pictures) barlav Windows and Doors 4 06-14-2011 07:31 AM
Stationery / Transom / Picture window ??? CoconutPete General DIY Discussions 7 02-04-2011 10:36 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Transom Window installation question Ladybird Remodeling 6 09-15-2009 06:12 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
