Window AC Questiond - HVAC - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 05:20 PM   #1
Window AC Questiond
Hi, I have some questions about window air conditioners. My old Kenmore just went bad, so I bought a new LG 8,000 btu unit from Home Depot (Model # LW8011ER). I installed it and it seems to be working fine so far, and cools very well. I chose it over Frigidaire because I had heard LG was good and I liked the 5 year warranty... HVAC people, Did I make a good choice? Also, I noticed that inside the unit, there is a plate of styrofoam screwed in behind the blower fan, where the unit borders the outside air. Is this a reliable material? Will it hold up ok? What exactly is it? The unit is pretty powerful and quiet overall...I just wanted a model I could install and that will last me for 5-10 years and not have to worry about it. I also like that it drains water well which I have heard Frigidaires did not. Id just like some insight about the styrofoam piece inside the unit, and what it is for. Thanks.
diyguyky is offline   Reply With Quote
Old 05-25-2011, 06:36 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,102
The same fan exhausts the hot air and brings in the cold air so you have a hot and cold compartment and the styrofoam prevents heat transfer between them. It is a hard closed cell foam and I have never seen one fall apart. I hear good things about LG appliances. Friend is a nurse and works with lots of women and they like LG and she is buying their appliances instead of MTag soon. I have a LG computer monitor and it works great.
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 07:03 PM
Rotted window frame bottom: Do I need to replace the whole window? Ginette Building & Construction 4 09-15-2010 09:52 AM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
