Williams NG Furnace Pilot Light Will Not Stay Lit - HVAC - DIY Chatroom Home Improvement Forum
Old 12-04-2011, 09:26 PM   #1
Williams NG furnace pilot light will not stay lit
I purchased a Williams NG furnace a couple of months ago, and the pilot light goes out several times a day. It's the 30,000 BTU model Model# 3003622 available at Home Depot. I had an HVAC guy install it. Then last week I had a different HVAC guy check the millivoltage of the pilot generator, and he got a reading of 90. He said the problem is either with the pilot generator, or the wind blowing the pilot out through the outside vent. it hasn't been windy, and Williams says that it should be 140 minimum. So I explained the situation to them via email, and have asked for a replacement pilot generator.
If anyone has any advice it would be greatly appreciated!
zBernie is offline   Reply With Quote
Old 12-04-2011, 10:06 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Nothing more you can do until you get the new generator which appears to be the problem.
Doc Holliday is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
turn off pilot light on gas furnace safe? gingerdrass HVAC 1 07-01-2011 02:42 PM
Pilot Light works once, then have to re-light after furnace goes off aransas42 HVAC 8 09-30-2009 07:49 AM
pilot light does not stay lit bwquinn HVAC 2 09-17-2009 09:00 PM
pilot light reignition on older williams model Unregistered HVAC 1 02-17-2004 09:26 PM
