Old 12-10-2009, 04:20 PM   #1
Williams gravity vented wall furnace
Hi!
I have a Williams gravity vented wall furnace, model #: 3509622, serial #: J 094628.
The problem that I am having is that, once I set the thermostat to a specific setting it will turn on, but I can't feel any heat coming from it.
Usually I can feel the heat above the pilot door opener and above, but now I can't feel heat coming out.
Looking at the picture below:
In the RED section, I can feel heat coming from it.
In the YELLOW section, I can't feel the heat at all. It worked fine last year and I've been cleaning it and taking the dust off...
Please help.
pald is offline   Reply With Quote
Old 12-10-2009, 10:18 PM   #2
the red section is where youre going to feel the heat initially after its on for awhile you will feel it in the middle section as it gets to operating temp just let it run longer
kennzz05 is offline   Reply With Quote
Old 12-11-2009, 12:36 AM   #3
Usually it will start about 15-25 minutes, but I would leave it on for hours and it does nothing, only the above part only. It sucks when the kids want some heat and they can't feel it because they are short.
wall venting 60,000 BTU fuel oil furnace Steve Burke HVAC 1 11-11-2009 05:58 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 08:06 AM
Williams wall heater shuts off ezwriter HVAC 7 01-01-2009 11:54 PM
Williams wall furnace whistling noise diyer_mi HVAC 11 10-23-2007 05:05 PM
Williams wall heater produces black smoke skark_burmer HVAC 2 02-24-2005 08:15 PM
