Old 10-07-2011, 10:02 PM   #1
Will new induced draft blower work?
HVAC technician recommended I replace old blower. New blower specs are a bit different, so I am worried it may not work or have bad performance.
Old Blower: 120 V 1.3 A 60 Hz 3400 RPM
New Blower: 120 V 1.7 A 60 Hz 3000RPM
fidel is offline   Reply With Quote
Old 10-07-2011, 10:47 PM   #2
Find the right one here:
http://www.fasco.com/documents/pgs068-095.pdf
http://www.fasco.com/documents/pgs051-059.pdf
Then order someplace like here
http://www.cshincorporated.com
Not that difficult for a handy DIYer.
diyorpay is offline   Reply With Quote
Old 10-07-2011, 11:16 PM   #3
JJboy's Avatar
I think is off. HP, AMPS and RPM need to be close to the original
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-08-2011, 01:30 PM   #4
I went ahead and installed the blower and it works. I'll let you know if any problems develop, but it seems to work just fine.
(it was an easy job: remove mounting screws, disconnect 3 wires, remove old blower, put-in new blower, screw back mounting screws, reconnect 3 wires)
Old 10-08-2011, 01:43 PM   #5
JJboy's Avatar
being dramatic, your bill will be increased, and low CFM, less confort in the hot days....yes it will work normal
DIY Electrical work in New Jersey electures Electrical 42 12-19-2012 04:19 PM
New work vs Old work Tetranitrate Electrical 3 07-12-2011 09:19 AM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
Replacing Fasco 7062-3136 draft inducer blower on my Bryant Gas Furnace thalweg76 HVAC 0 02-20-2010 04:35 PM
Blower cycling and vibration whatshappening HVAC 1 02-09-2010 05:48 AM
