Will The New CTK03 Control Basic Function.. - HVAC - DIY Chatroom Home Improvement Forum
Old 07-29-2013, 09:43 AM   #1
Will the New CTK03 control basic function..
Will the New CTK03 control basic function of my outside condenser (Goodman ssx160361a 3Ton 16seer) ??
I realize that the setup wont be ideal.. But my furnace (Goodman GCVM960604cx) is Comfortnet compatible...And was hoping that the thermostat would control all of its functions,...while at least controlling basic function of my outdoor unit ..even though it is not comfortnet compatible?
Any info appreciated
Thx
adaddo is offline   Reply With Quote
Old 07-29-2013, 10:22 AM   #2
CTK03 Install manual.
This control may only be used with certain system configurations. Valid system configurations for which this control can be used are:
• A communicating air handler matched with a communicating outdoor AC condensing unit.
• A communicating furnace matched with a non-communicating single stage AC condensing unit.
taxmantoo is offline   Reply With Quote
The Following User Says Thank You to taxmantoo For This Useful Post:
adaddo (07-29-2013)
Old 07-29-2013, 10:26 AM   #3
Thanks..to Taxmantoo
Thank you.... I'll be installing the CTK03 thermostat
Old 07-29-2013, 11:10 AM   #4
re: ctk03 work with non-communicating condenser
Hey taxmantoo... Is the information re the working ability of the ctk03 thermostat ...based on previous experience or can it be quoted from Goodman? The fellow I spoke with at the ac place stated that it isn't guaranteed to work "I would be going into uncharted waters"?
Any further info appreciated
Old 07-29-2013, 12:35 PM   #5
Click on my link for the install manual in my earlier post.
Open it up in Acrobat Reader (it's a pdf) and read page 3. That's where I got the information I quoted concerning the possible system types.
EDIT: I just flipped through the install manual and can't find the instructions for wiring a non-communicating AC. Maybe the furnace controls the AC unit? It sure doesn't look like there are any cooling outputs on the thermostat to connect the thermostat to the AC.
Here's the furnace install manual. Unfortunately it doesn't specify how to wire the non-communicating AC either.
Old 07-29-2013, 09:15 PM   #6
Thx once again 4 the followup
I spoke with Goodman tech support...they said it'll work fine and referenced this page. Thank you once again http://www.comfortnet1.com/FAQs/tabid/1766/Default.aspx
stating, A single-stage air conditioner, however, can be connected using the Y1 and C terminals on the furnace’s control board.
Turn thermostat to COOL (mobile home split system), fuse on control board blows. justplumducky HVAC 8 04-29-2013 08:42 PM
add remote control function to a roller door samjesse Electrical 6 12-04-2011 08:10 PM
Dual Control ceiling fan and light Dickens Electrical 10 08-05-2011 09:29 AM
Ceiling Fan Speed Control czars HVAC 0 01-14-2010 09:06 PM
