Will Condenser Coil Damage/blockage Cause Air To Exit Grill Horizontally? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-05-2013, 05:49 AM   #1
Rewards Points: 1,592
Will condenser coil damage/blockage cause air to exit grill horizontally?
Air is coming out of condenser top grill almost horizontally instead of almost vertically.
At least 1/3 of total condenser surface area is damaged. I've previously posted a similar thread, so I'm aware of some of the other causes, but I never mentioned the condenser coil damage before.
Is this a possible cause?
justplumducky is online now   Reply With Quote
Old 10-05-2013, 06:07 AM   #2
An old Tradesmen
Rewards Points: 6,892
That would decrease air flow, but not make it come out the sides.
The Following User Says Thank You to beenthere For This Useful Post:
justplumducky (10-05-2013)
Old 10-05-2013, 09:24 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,834
Wrong fan blade/different pitch, maybe somebuddy changed it with whatever wuz available?
The Following User Says Thank You to yuri For This Useful Post:
justplumducky (10-06-2013)
Old 10-06-2013, 05:43 AM   #4
Will these conditions (at least 1/3 blockage of condenser coil surface area & air out sideways) affect the degree of cooling? Raise pressures in system?
If position of fan blade ass'y were slightly too high or too low on motor shaft, air out sideways then?
Old 10-06-2013, 06:56 AM   #5
An old Tradesmen
Too low will cause air to come out the sides.
Yes, 1/3 block age will decrease cooling capacity, and raise the pressures.
Goodman 3 ton condenser (ssx160361ab) with Goodman (CAPF4860C6) 4 - 5 ton coil ? adaddo HVAC 3 08-01-2013 10:40 PM
condenser coil sizing sammy37 HVAC 6 05-02-2013 04:52 PM
New 410a condenser with old coil.... simeltzer HVAC 31 03-10-2013 05:39 PM
AC - Coil leaking fcabanski HVAC 7 07-04-2012 09:50 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
