Will This Burn Up A Blower Motor? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-30-2008, 08:15 AM   #1
Will this burn up a blower motor?
What will happen if I energize two terminals on a 3 speed motor at the same time. For instance putting 120VAC to the low speed (red) and the high speed (black) at the same time.
Will this damage the motor or just kick it into one of those speeds?
I'm trying to add a custom mod to my furnace to control the fan speed and can't seem to find any internal diagrams on how a 3 speed motors works.
Thanks.
dac122 is offline   Reply With Quote
Old 10-30-2008, 08:33 AM   #2
Idiot Emeritus
Rewards Points: 1,492
Only one speed can be energized at a time. If more than one is energized, the motor will 'fight itself' because it's trying to go at two different speeds.
Rob
micromind is offline   Reply With Quote
Old 10-30-2008, 09:20 AM   #3
Micro is right. as the motor operate the unused motor tap have a measurable back EMF that is just looking for a place to go. Two diff speeds hooked together give it that pathe and will cook the windings.
hvaclover is offline   Reply With Quote
Old 10-30-2008, 09:40 AM   #4
If you look at the motor there is a diagram on there that tell you what each wire is for. You might have to pull the motor out to see that diagram.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-30-2008, 10:19 AM   #5
Thanks. That is what I suspected. Knew you guys would have a definitive answer.
Old 10-30-2008, 02:42 PM   #6
~grumble~ how many times you pull a motor and the diagram is so singed you can't read it?
Old 10-30-2008, 04:26 PM   #7
Well I am an optimist. I like to think they are as nice a clean as when I put them in.
Old 10-31-2008, 05:12 AM   #8
An old Tradesmen
Rewards Points: 7,372
Black=High
Blue=Med High
Yellow=Med Low
Red=Low
White=Common
And, yes. 2 windings energized at the same time, lets the magic smoke out.
Lennox G12 Blower Motor Problem jimvh2 HVAC 15 03-19-2016 11:27 AM
Blower Motor Wiring Help atvguy64 Electrical 11 08-14-2015 09:02 PM
Trouble shooting a Blower Motor cougar HVAC 10 07-15-2008 08:14 AM
Blower motor wiring help!! atvguy64 HVAC 4 02-04-2008 08:27 PM
Looking for blower motor capacitor dditch66 HVAC 3 11-26-2007 07:35 PM
