Will Bad Blower Control Board Keep Compressor From Coming On. - HVAC - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 08:19 PM   #1
Will bad blower control board keep compressor from coming on.
Have no air conditioning whatsoever. It is a single compressor with two zones controlled by dampers and a zone board. I suspected the zone controller board since it fails frequently and i was right. Wired upstairs thermostat to equipment to at least have ac upstairs but am getting nothing. The thermostat is calling for cooling but the unit is not coming on. I took the door off the furnace unit and found no diagnostic lights lit on the surelight board. There is 120V to the board but nothing happening. I took off the surelight board and there is a badly burned spot on one of the traces on the back. My question is will this prevent the outside unit from coming on. I can manually press the contacter and the outside unit comes on. I am going to replace the zone controller board and the surelight board but want to make sure that i shouldnt have any other issues. Thanks in advance for any help you can provide.
tonsinnc is offline   Reply With Quote
Old 05-28-2012, 09:45 PM   #2
Rewards Points: 616
it could....
carmon is offline   Reply With Quote
Old 05-28-2012, 09:45 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Yes, board is bad and will not be able to direct any low voltage control. Might want to check the transformer as well.
Thanks.
Doc Holliday is offline   Reply With Quote
New control board or fix it? Bobeht HVAC 26 01-18-2012 03:03 PM
Can't get new furnace control board to work uvalaw HVAC 17 04-24-2011 09:56 AM
York gas heater control board replacement spyvan HVAC 5 12-29-2008 07:12 AM
Blower control board mlmaher HVAC 1 11-24-2007 01:39 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 09:33 PM
