Will A 4T Evap. Coil W/50' Lineset Suck In 21 Oz R22 At 500 Microns? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-20-2007, 12:57 PM   #1
Will a 4T Evap. Coil w/50' Lineset suck in 21 oz R22 at 500 microns?
I'm getting pretty close to completing my 4T air handler/HP installation.
Final steps will be to connect the lineset, pressurize with N2, leak test, evac. to <500 microns and charge.
I need to add exactly 21 oz of R22 to account for my 50' lineset. (factory charge assumes 15' and they say to add .6 oz/ft over 15').
I'm just curious if all 21 oz will be sucked in while the lineset/evap. coil has been brought to 500 microns of vacuum. (ie Will this level of vacuum be enough to bring in all 21 oz. or will I need to fire up the unit and use the suction port to bring in any remaining charge?)
(I do have an accurate digital scale)
TIA
hennyh is offline   Reply With Quote
Old 02-21-2007, 11:49 AM   #2
coolmen's Avatar
Yes . just make sure the r-22 is stored in room temp. if its cold out side/in the van. a cold r-22 can will have less pressure.
coolmen is offline   Reply With Quote
Evap coil question merlinfolks HVAC 15 07-27-2009 07:20 AM
