Will 3 Ton Compressor Work In 2.5 Ton Unit? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-07-2012, 08:09 AM   #1
Will 3 ton compressor work in 2.5 ton unit?
I have a 2.5 ton Goodman ac unit that the Bristol compressor inside died. Model # on the compressor is H29B28UABCA. On ebay I can buy the same model compressor but in a 3 ton. Will it work in my 2.5 ton unit?
jcljr166 is offline   Reply With Quote
Old 02-07-2012, 08:15 AM   #2
no......to many problems to list here, just take my word for it, Don't do it.
dosy777 is offline   Reply With Quote
Old 02-07-2012, 08:20 AM   #3
It COULD work....but the mechanics in trying to find the balance point with a TXV are too tricky to be reliable.
Have your indoor coil checked...alot lot of Goodman coils were dual rated (2.5 to 3 ton in same coil) would probably need a a larger piston however in the indoor coil.
hvac5646 is offline   Reply With Quote
Old 02-07-2012, 10:26 AM   #4
Rewards Points: 77
Make sure you check the run cap sizes, may need to replace
Filtration / HVAC & Indoor Air Quality Solutions
AirstarFilters is offline   Reply With Quote
Old 02-07-2012, 12:24 PM   #5
On second thought i have to change my mind to a definite 'no".
i thought you were changing the condensing unit....not just the compressor.
The 2.5 condenser is too small to handle the amount of heat rejected by a three ton. You would end up over heating the compressor and cooking it. Sorry.
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 04:07 AM
new r-410a ac unit installation procedure(w/old unit r-22)? excalibur1 HVAC 0 06-06-2011 03:47 PM
Window A/C Unit and Supplying Power JayEnder Electrical 1 04-30-2011 07:50 PM
Inside Unit Runs, Outside Unit Runs (with help) no cold air beakon20 HVAC 4 08-13-2008 09:33 PM
