WiFi Thermostat W 240V Baseboards? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-24-2013, 05:09 PM   #1
WiFi Thermostat w 240V baseboards?
I'd like to install a wifi-enabled thermostat to control 2 electric baseboards. Current thermostat is a 25-year old Honeywell dial, 2-wire connection. No c-wire, etc. Is there a way to get a product like a Nest to work with a 24V relay, or the like? Anyone done this before? Any advice appreciated.
Cheers
Thingy is offline   Reply With Quote
Old 09-24-2013, 05:27 PM   #2
This would work with a wifi thermostat.
http://www.smarthome.com/300612T/Aub...sformer/p.aspx
RoyalAcresRod is offline   Reply With Quote
Old 09-24-2013, 05:53 PM   #3
Rewards Points: 6,652
See http://www.enernetcorp.com/baseboard...plication.html This one will integrate with Insteon Tech. http://www.smarthome.com/300607B/Aub...rmostat/p.aspx
Also the Honeywell EConnect RedLink http://www.morelectricheating.com/pr.../ECONNECT.aspx PDF on the Econnect system http://www.forwardthinking.honeywell...ct/50-1784.pdf
Relay that will allow you to control 240vAC appliances with a low voltage type thermostat http://www.pexsupply.com/White-Rodge...VAC-14415000-p
Old 09-24-2013, 07:37 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
Personally I would go with the EConnect redlink setup.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 09-27-2013, 12:15 PM   #5
Thanks all- that's got me in the right direction.
Attic fan using z-wave thermostat C03T07C12 HVAC 1 05-28-2013 09:44 PM
Need help replacing an OLD General Controls Thermostat ohman HVAC 3 06-08-2011 05:35 PM
Heat but no A/C with new thermostat myqhenry HVAC 15 05-30-2011 10:53 PM
Warm tiles 240v thermostat cybertone Electrical 41 01-07-2010 09:07 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
