Old 06-01-2010, 10:33 AM   #1
Why won't furnace restart?
After taking apart my condensate pump to clean it and then reinstalling it I can't get the A/C furnace to restart. Nothing will come on (heat pump, or blower). the thermostat looks normal and says it is cooling. I assume there is a way to reset this but can not figure out how. I have checked fuses at the panel and on the blower, and heat pump. I even did the turn it off twice in 30 seconds with no success. It is a 5 year old American Standard, heat pump. Any ideas are appreciated. Its getting hot in the house!!!
Randy6 is offline   Reply With Quote
Old 06-01-2010, 10:59 AM   #2
fabrk8r
fabrk8r's Avatar
Did you happen to remove the door from the blower compartment at any time? Check door switch.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 06-01-2010, 05:46 PM   #3
Hvac Pro
Does the condensate pump have an extra overflow switch connected to 2 wires besides the main wiring. The switch is on the pump and if it is stuck open (thinks there is a high water level issue) then it stops 24 volts to the furnace. May just need to reset the switch or check its float to see if it is stuck in the up position.
Old 06-01-2010, 09:39 PM   #4
Bypass the cond. pump safty switch then turn the t-stat to fan on.
If the fan comes on its your cond. pump.
If there is no fan check to see if you blew a fuse in the air handler.
Sounds like you shorted out the low voltage wires.
mikethe ductman is offline   Reply With Quote
Old 06-02-2010, 04:13 PM   #5
I tried bypassing the pump and still did not get it to run. In the end it was the low voltage fuse. Thanks for the help
Old 06-03-2010, 07:13 AM   #6
This is a common mistake for that problem. As an HVAC guy myself, I've heard techs going to homes just to properly replace the blower door. I've done it myself on my own furnace just the other day.
Mr_Rice is offline   Reply With Quote
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Trane XE 80 Furnace - flame out and restart Thome HVAC 3 10-12-2009 06:27 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
