Old 11-05-2012, 11:21 AM   #1
Why won't the blower stop?
Hi all,
my heat pump starts and runs fine. When the inside temp reaches the set thermostat temp the blower is supposed to stop but it never does (unless I cut power off to the unit by hand). The heat flow stops but the blower continues to run. This is a goodman manufacturer heat pump. Any ideas anyone? What do I check? thanks all
cyp555 is offline   Reply With Quote
Old 11-05-2012, 12:44 PM   #2
do you have the manual blower switch pulled out inside the furnace...This happened to me and I forgot to put it back to auto. Could also be a faulty switch.
lucid484 is offline   Reply With Quote
Old 11-05-2012, 12:51 PM   #3
No, it is not manual. It should shut off automatically. Where exactly is the blower switch inside the unit?thanks
Old 11-05-2012, 12:56 PM   #4
Mine is inside the furnace on the top left...Its right in the box where you set the Temperature activation for High,Low,Safety temps on the blower unit.
Old 11-05-2012, 05:12 PM   #5
An old Tradesmen
Check to see if the wire connected to the G terminal on the thermostat and at the furnace is shorted to one of the other wires.
Also, post full model number of your unit.
Old 11-05-2012, 06:10 PM   #6
remove wire of terminal G at control board see if it stops. after you check what beenthere suggested 1 st....ben sr
Old 11-06-2012, 04:44 PM   #7
hi guys,
I checked . the green wire connects to a light brown wire at the unit. I did not see a green wire at the unit end. should I still discoonect and see what happens?
Old 11-06-2012, 05:02 PM   #8
An old Tradesmen
Yes. And also make sure that the brown wire at the unit, is the fan control wire. there should be a wiring schematic on one of the panels.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (11-06-2012)
Coleman Gas Furnace/Air Conditioning unit's blower won't stop MarchandDeBoeuf HVAC 4 07-19-2012 03:19 PM
Comfortmaker blower problem rerobins HVAC 2 01-06-2010 11:38 AM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 02:21 AM
Blower keeps cycling on and off simonb HVAC 1 01-17-2009 11:56 AM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 10:08 PM
