Why Is This Red Wire Not Plugged In? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-23-2008, 08:59 PM   #1
Why is this red wire not plugged in?
Hi all, every winter I have to open the front pannel on my roof top Carrier A/C unit and reset the gas valve to make the heater work. Well this summer I had an A/C tune-up done and today I went to reset the gas valve and noticed a loose red wire.
There are three wires coming off the pilot lighting system: two plug into some kind of a control unit. The red wire is not plugged in, its just sitting next to an open plug numbered 5. The red wire runs to a probe about an inch long that burns bright red when the flames start to blow. The heater works fine that we have noticed, should I plug this wire in?
thanks for the help.
jrtulare is offline   Reply With Quote
Old 11-24-2008, 01:51 AM   #2
either trace the wireing diagram or see if you can take a pic of the part/ and diagram and post it
kennzz05 is offline   Reply With Quote
Old 11-24-2008, 08:35 AM   #3
An old Tradesmen
Rewards Points: 6,160
Was the ignition module changed out recently, or last winter.
If so, they may be using a module that uses the internal sensor instead of teh external flame sensor.
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 05:13 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
