-   -   Why is this red wire not plugged in? (http://www.diychatroom.com/f17/why-red-wire-not-plugged-32489/)
jrtulare 11-23-2008 08:59 PM
Hi all, every winter I have to open the front pannel on my roof top Carrier A/C unit and reset the gas valve to make the heater work. Well this summer I had an A/C tune-up done and today I went to reset the gas valve and noticed a loose red wire.
There are three wires coming off the pilot lighting system: two plug into some kind of a control unit. The red wire is not plugged in, its just sitting next to an open plug numbered 5. The red wire runs to a probe about an inch long that burns bright red when the flames start to blow. The heater works fine that we have noticed, should I plug this wire in?
thanks for the help.
kennzz05 11-24-2008 01:51 AM
either trace the wireing diagram or see if you can take a pic of the part/ and diagram and post it
beenthere 11-24-2008 08:35 AM
Was the ignition module changed out recently, or last winter.
If so, they may be using a module that uses the internal sensor instead of teh external flame sensor.
