Why Is My Heatpump Leaking Indoor's? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-31-2012, 03:12 PM   #1
why is my heatpump leaking indoor's?
everything runs normal it just leaks water down the coil and drips into the bottom of the unit, you can see in the pictures
http://i333.photobucket.com/albums/m...-46-42_506.jpg
http://i333.photobucket.com/albums/m...-48-04_916.jpg
jus put up new links
cjw615 is offline   Reply With Quote
Old 08-31-2012, 03:57 PM   #2
the links aren't working for me
Old 08-31-2012, 05:15 PM   #3
biggles's Avatar
condensate is blocked up monkey vomit in the trap...
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 06:00 PM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 05:40 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 05:43 PM
Ice and Water Shiled over or under Drip Edge? Leaking Roof sbt3 Roofing/Siding 8 05-03-2008 12:00 AM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
