Why Manual Labor ? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-21-2012, 12:13 PM   #1
why manual labor ?
I only have two wires connected to thermostat, (red, white) i have a green NOT doing anything, I have a switch to cout power off at furnace, red, white IS connected at furnace, furnace ignites and works fine as long as turn toggle off, cross-red. white wires, flip toggle-works great, turn toggle off connect red, white to RTHL111(with new alk. batt.), flip toggle, nothing on therm. screen, I have a new circuit card in it, the red led does NOT come on when therm. is on it?, can you help?
plurbina is offline   Reply With Quote
Old 12-21-2012, 05:34 PM   #2
Rewards Points: 582
pictures would help us help you...from what it sounds like ..either bad stat..or open saftey switch...ben sr
Old 12-21-2012, 08:54 PM   #3
Houston204's Avatar
Rewards Points: 556
What terminals did you wire the red and white wires to on your new thermostat?
Houston204 is offline   Reply With Quote
Day Labor Hiring mcss Building & Construction 6 07-06-2011 05:31 PM
Manual D Friction Rate Worksheet kilosos2 HVAC 38 01-11-2011 04:36 PM
How do you find help with the manual labor ? bluejeans General DIY Discussions 15 06-06-2010 12:35 PM
Need help evaluating estimate- labor component ajm_ct HVAC 7 12-30-2008 04:42 PM
labor costs per sq. ft. awk08 Building & Construction 1 04-06-2008 09:12 PM
