Why HVAC Install Shouldn't Be Price Driven - HVAC - DIY Chatroom Home Improvement Forum
Old 05-07-2011, 11:34 PM   #1
HVAC Supermodel
unicursalhex's Avatar
Rewards Points: 150
Why HVAC install shouldn't be price driven
This heat exchanger came from an $800,000 house that the installing contractor botched, they not only botched this house but all others in the development. This 12 year old 80k BTU 3 ton furnace had 2 8x20 returns, both using only the wall cavity one of which was completely blocked with insulation. The supply duct was 10x11... This heat exchanger didn't have a chance. When I showed up for a maintenance I fired up the furnace and felt a massive amount of heat coming from the blower compartment, you could fry an egg on the firewall (downflow). At that point I was sure the heat exchanger was blown, pulled the blower and found the cracks. Anyway, just wanted to show the homeowners here what happens when you don't make an informed, non-price driven decision when it comes to your HVAC system, cracks like these are bad for your health!
Mark it zero!
unicursalhex is offline   Reply With Quote
Old 05-08-2011, 07:56 AM   #2
Rewards Points: 292
Good information.
I have often described my (new home) installation, as 'installed by a drunk'.
The ductwork, both supply and return, had many leaks. One, a rather large leak, hidden on the return trunk in the basement, must of had us breathing CO for 20+ years.
Another gem was, where a run elbowed around cinder block making it short of the wall oval elbow (terminology?) by several inches. I had to chisel out some of the block to bring the ends together.
Worst of all, was when we first fired up the furnace and smoke filled the basement. Seems there was a short of power wires against the frame. The tech (owner) fixed the short, but didn't change the melted wires. Seems he just tucked them into the inside corner of the furnace. Didn't discover it until system changeout 20 years later.
V
veesubotee is offline   Reply With Quote
Old 05-08-2011, 09:54 AM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Unless your heat exchanger was cracked or your flue vent pipe was leaking, no CO would make it into your home via only leaky ducts. Certainly your system would be less efficient with leaky ducts but CO would have nothing to do with it not too mention I highly doubt you would have lived 20 years breathing CO.
And it is very unethical and very unprofessional, far less than amatuer, to chip away at anything which not so loosely translated would also be described as deforming your home, to connect ducts. Buy the duct and extend it.
Just saying.
Doc Holliday is offline   Reply With Quote
Old 05-08-2011, 11:42 AM   #4
An old Tradesmen
Rewards Points: 6,098
CO from a furnace, is commonly drawn in through a leaky return duct. Seldom does a cracked heat exchanger put CO into the supply duct. The heat exchanger on an 80% is a negative vessel, with a positive pressure on the outside of it. So CO seldom comes from the crack it self.
Old 05-08-2011, 11:46 AM   #5
Rewards Points: 292
I should have added that when the furnace was running, I was getting some back-drafting from the WH. The leaky return ducts plus the hidden gap didn't help.
When the run was installed, the contractor chipped the end of the block, but not enough. There was no way to replace the piece of duct as it was captive between the top edge of the block and the ceiling beam. The gap was less than 6", so the only way to do it was to chip a little more away.
Just saying.
Like I said, the system was installed by a drunk. I agree with your statements, but it is (was) what it is (was). I have fixed all of the leaks.
On another note, what's a huckleberry?
Old 05-08-2011, 02:09 PM   #6
The Following User Says Thank You to Doc Holliday For This Useful Post:
operagost (05-11-2011)
Old 05-08-2011, 02:13 PM   #7
"You are no Daisy, you are no Daisy at all."
Old 05-08-2011, 02:18 PM   #8
I am not following or understanding any of this. The blower is first, then the heat exchanger and then the supply so how does the return, the very low negative pressure air flow on the far back of the furnace outwiegh the high velocity and volume just after the furnace on the supply side? Where is this CO being sucked back in to the return from if the blower is pushing it out of the supply side, return leak or not? We are talking a cracked heat exchanger with a return air leak and a cracked heat exchanger without a return air leak.
Can you explain, please?
Old 05-08-2011, 02:29 PM   #9
An old Tradesmen
The heat exchanger, if it is cracked, will not put CO into the air directly. It may blow back through the burners out into the furnace room, where the return duct leakage, and or loose/open air filter bracket will draw it in. And then blow it into the supply plenum and duct.
The heat exchanger of an 80% is under a negative pressure, so there is no pressure to the blow the CO out into the supply plenum or duct.
Old 05-08-2011, 02:52 PM   #10
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Ouch that's nasty... did not realize it was under negative pressure though, but guess it makes sense, so the draft inducer motor is after the heat exchanger so it's sucking air from outside, through the burner then heat exchanger, then pushes it outside. I'm sure it's still a huge efficiency loss though.
This is why CO detectors are important. If by chance it did let CO in, you'd be informed about it. Though most people just go take the batteries out... lol
Duct tape should fix that good as new.
Old 05-08-2011, 05:35 PM   #11
HVAC Supermodel
Rewards Points: 150
Maybe heating's just not your game, I know lets have a spelling contest!
Mark it zero!
Old 05-08-2011, 06:15 PM   #12
Wire Chewer
Rewards Points: 46
I'm guessing it works like what I said, but maybe someone can correct me, I'm not a hvac expert.
A picture is easier then trying to explain it. I'm sure it's more complicated than that, as I think there is actually a secondary heat exchanger, and probably a bunch of regulators and stuff to ensure the maximum clean combustion.
Old 05-08-2011, 07:05 PM   #13
Old 05-08-2011, 07:25 PM   #14
Roddy's Avatar
That pic is an older style furnace which relies on natural draft, beenthere is talking about the new style 80% er's that use a small fan to draw the exhaust through the heat exchanger.
Undersized ductwork and oversized furnaces are very common, I hate telling people that their 4 yr old purchase is almost worn out. Furnaces, just like all our other appliances just can't take the abuse like the old stuff. They must be installed correctly!
Roddy is offline   Reply With Quote
Old 05-08-2011, 07:53 PM   #15
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
new 3 ton hvac Payne units. No cool air comes out when fan, compressor,thermostat run runbikeengr HVAC 10 04-10-2007 06:59 PM
