Old 11-01-2009, 07:10 PM   #31
old pro
Up until 1990 that technique worked if everything matched etc. The newer higher SEER units run lower suction and discharge pressures and temp split because of higher capacity fans and now we have to use superheat and subcooling. A few old timers like myself have real good instincts. You have to have 10 or more years experience and understand the matchup of the system components, house insulation etc etc. Only a lot of experience gets you to that point.
Old 11-02-2009, 11:56 AM   #32
Originally Posted by thehvacguy View Post
Oh, yuri, I have heard about the beer can cold method of charging but I havent been explained in detail. I know thats how my boss does it. He charges the system until the suction line is cold and checks for the 20 degree split and goes from there.
If the system has a TXV then that method could be masking the symptoms of an incorrectly charged system.
hennyh is offline   Reply With Quote
Tags
coil, iced, troubleshooting
More On This Topic
This is just actually the shell of a fork, because I want to show you guys what the difference is. So these are called lowers, they're usually cast out of magnesium, they can either have a through axle or you know, a normal quick release axle like this... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip, I'll be taking about the automatic suction shut off. As the level of liquids rise in the tank, this internal float is going to seep itself up against the seal at the intake of the motor... Read More »
Hi! I’m Roy Stringfellow for expertvillage.com. We’ve build our coil pot up to about this size and the next thing that we’re going to do is pull it out of our form, which is kind of tricky sometimes. You’ll notice this is kind of... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
Learn the meaning of the Gilt Leaf Seer and how to use it when you play 'Magic: the Gathering' in this free video. Read More »
Evap Coil Replacement Rickhoff HVAC 3 08-24-2009 11:58 PM
Evap coil question merlinfolks HVAC 15 07-27-2009 09:20 AM
Accessing evap coil - creating a reusable access panel bifjamod HVAC 1 07-07-2009 02:14 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 03:45 AM
Access to CPC13H evap coil.. bginvestor HVAC 1 06-27-2008 11:40 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
