Old 10-31-2009, 06:30 PM   #16
Well First I attach my manifold gauges to the service port on the condensing unit. Then I attach my yellow hose to the vacuum pump. Then I proceed to pull a vacuum through the low side gauge. I understand that the hoses on the manifold may have some refrigerant oil leftover from the last job but how could the system be contaminated if the vacuum is pulling everything out of the system?
thehvacguy is offline   Reply With Quote
Old 10-31-2009, 06:40 PM   #17
An old Tradesmen
System may not be contaminated. But, if your hoses are. You won't get a good reading. And can end up chasing your tail trying to find out why.
Old 10-31-2009, 08:28 PM   #18
as seen on tv
You can use copper refrigeration tubing with flare nuts on the ends to connect to gauge ports and such
qbert is offline   Reply With Quote
Old 10-31-2009, 08:31 PM   #19
as seen on tv
faster recovery=liquid first vapor last. keep a bottle in a vacuum and refrigerate it for fast recovery
Old 10-31-2009, 08:36 PM   #20
An old Tradesmen
We're still working on vacuum. We didn't get to recovery yet.
Old 10-31-2009, 09:12 PM   #21
old pro
Should I tell him about the "beer can cold" technique of charging?
Old 10-31-2009, 09:16 PM   #22
An old Tradesmen
Your in a mean mood tonight.
Old 10-31-2009, 09:24 PM   #23
old pro
Yeah, the weathers getting harsh here and I'm trying to figure out how to make "Freedom 55" work.
Shoulda been born rich instead of handsome.
Old 10-31-2009, 09:29 PM   #24
An old Tradesmen
Old 10-31-2009, 09:36 PM   #25
Old Newbie
How harsh is it?
Still waiting.
tinmanrob is offline   Reply With Quote
Old 10-31-2009, 09:58 PM   #26
old pro
-2degC but the damn north wind is up to 40km/hr. Some kind of huge Colorado low. Blame the Yanks.
Old 10-31-2009, 10:12 PM   #27
Old Newbie
A tropical +8C here.
Old 11-01-2009, 02:36 AM   #28
I guess we should be nice and tell you that a dirty evap. coil, dirty filter, indoor fan motor running too slow or squirell cage clogged with all kinds of stuff can make it ice up also.
mikef54 is offline   Reply With Quote
Old 11-01-2009, 06:43 PM   #29
LOL You know, I hate California but when I hear about it being below 0 in other places I am grateful for the southern california sun. Well, mike, thanks for your input. I knew all of those things would cause a frosted coil. Also if the TXV is bad that could cause a frosted coil too. I was just wondering why a low charge would cause a frosted coil. Now I know why is because lower pressure causes lower temperature in the lines. I actually was learning the recovering technique in class on friday and the teacher had us set the recovery machine to vapor the whole duration of the recovery. The unit we worked on was a three ton unit which is small but it didn't take too long for recovering vapor. My question is this: When recovering liquid, does it matter which part of the recovery tank you hook up to? (The red knob or the blue knob? When we recovered vapor we hooked up the hose to the blue side of the tank)
Old 11-01-2009, 06:46 PM   #30
Oh, yuri, I have heard about the beer can cold method of charging but I havent been explained in detail. I know thats how my boss does it. He charges the system until the suction line is cold and checks for the 20 degree split and goes from there.
Tags
coil, iced, troubleshooting
More On This Topic
The next topic we are going to cover is Recovery. That's basically the ability to recover mentally and physically from the wear and tear on your body from running. The most important part of the recovery is going to be getting an adequate night sleep. It... Read More »
Creating a Clay Coil Knob
Creating a Clay Coil Knob by Expert Village
So now I'm going to show you a couple of different options for making a knob for your pot. First I'm going to show you how to make some knobs that you'll attach, I'll also show you how to pull a knob, I'll show you how to throw a knob, they're so many... Read More »
Learn how to clean the volume pots (knobs) on a fender stratocaster electric guitar in this diy guitar tech video. Read More »
The first move we are going to talk about, we are going to talk about the neutral stance. And this is the type of ball, a ball that is in front of you, you have a chance to step into it and kind of attack the player. So this is more for that forward type... Read More »
The amount of time to recover from a mastectomy depends on the extent and length of the surgery, the overall health of the patient and following the doctor's post-operative orders. Immediately following the surgery, you will be taken to the recovery room... Read More »
Evap Coil Replacement Rickhoff HVAC 3 08-24-2009 11:58 PM
Evap coil question merlinfolks HVAC 15 07-27-2009 09:20 AM
Accessing evap coil - creating a reusable access panel bifjamod HVAC 1 07-07-2009 02:14 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 03:45 AM
Access to CPC13H evap coil.. bginvestor HVAC 1 06-27-2008 11:40 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
