Why Does My Furnice Not Turn On - HVAC - DIY Chatroom Home Improvement Forum
Old 10-18-2009, 10:34 AM   #1
Question
Why does my furnice not turn on
im having problems with my trane furnice. I noticed there was no flame in the piolit so i chanced the thermocoupler. I dont know what do do next. My next idea was to change the thermostat, but the Aircondition turns on, but the heater doesnt. I can also turn the blower on and it works. For some reason the heater will not turn on. What could be the reason?
MILTON is offline   Reply With Quote
Old 10-18-2009, 12:06 PM   #2
If the furnace is less than ten years old, there is a led light on the control board. It will flash x number of times. The flashing light is a "tattle tale". somewhere on the board or the door panel, there is a legend that will indicate what the problem is by the number of flashes. At least that is a starting point in diagnosing the problem. There is no sense in replacing parts without having an idea what is wrong.
You mentioned a thermocouple. Is this an older furnace?
Flashheatingand is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
blower won't turn on when heat is on, but will turn on when AC is on wavelength HVAC 6 12-31-2009 05:06 PM
Fan and A/C unit won't turn on cadmanim HVAC 1 06-22-2009 03:49 PM
Furnace w Cooling unit wont turn off Klatimer HVAC 2 09-19-2008 09:35 PM
Faucet won't turn off etiger Plumbing 1 08-31-2005 03:46 AM
