Why Does My Furnace Run For A Few Months Then Quit? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-13-2012, 06:00 PM   #1
why does my furnace run for a few months then quit?
after replace all components in my furnace mother board, glow plug ignition, pressure switch, flame rod sensor, my furnace fails to come on an cycle after a few months of running smooth....i have to shut the furnace off the turn it ...help i am tapped out an just had major back surgery an do not no what the problem is.... or what else to replace except for the inducer motor or thermostat
rickwest59 is offline   Reply With Quote
Old 02-13-2012, 06:03 PM   #2
HVAC Tech/ Browns Fan
Look like you replace everything but the furnace it self. So what is it doing? Not coming on at all? Is it short cycling? You been changing filters every 30 day?
Tator1076 is offline   Reply With Quote
Old 02-13-2012, 07:09 PM   #3
Did you replace the combustion restrictor ring behind the inducer motor?
Also if your filters got just medium heavy dirt the GUH model furnace was prone to over heating and and locking out.
hvac5646 is offline   Reply With Quote
Old 02-13-2012, 07:14 PM   #4
how
Rewards Points: 1,104
Hey HVAC5646
How did you know what furnace he has???
how is offline   Reply With Quote
Old 02-13-2012, 07:27 PM   #5
Checked his old post
Old 02-13-2012, 07:35 PM   #6
biggles's Avatar
supply voltage is solid 120V and true secondaries 24V,the fan squirrel cage is clean or dirt and dust,the furnace does it have AC on it with an A coil possibly dirting causing short cycling?did all those part changes happen one at a time and it ran OK...then another change of part and so on....was the stat original to the system not a digital add on.. to the exsisting transformer in the furnace.did you ever just jump R to W at the subbase and get a soilid cycle of heat that would ace the stat..VA within the transformer might be weakening making everything drag...even though you read a true 24V or better..typical is 40VA on installs or furnaces as shipped maybe go to a 50VA...were you blowing low voltage fuses at any time...
Old 02-13-2012, 09:03 PM   #7
Is it a condensing furnace and if so have you cleaned out the trap and lines?
dosy777 is offline   Reply With Quote
Old 02-13-2012, 10:20 PM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Who changed all of these parts out?
Maybe its time to get a differant troubleshooter on site instead of just throwing lots of money/parts at the problem
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-14-2012, 08:31 AM   #9
op diy'ed them.
for what the poor guy paid in parts he could have hired a pro.
That aside...that GUH has seen better days. There were too many design flaws with it, overheating with right sized duct work...throwing combustion rings.
PUT ONE IN WITH ALL NEW DUCT WORK AND WHEN i CLOCKED THE METER IT WAS FIRING AT 10K BTU MORE THAN NAME PLATE.
fACTORY TOLD ME IF i CHANGED THE ORIFICES THAT i WOULD VOID WARRANTY.??????
Old 02-14-2012, 05:00 PM   #10
Some new part is mildly overstressed because you haven't found the root cause and so it eventually fails.
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
Moving furnace & redoing ducting cbrc5eric HVAC 0 02-09-2012 08:13 AM
Furnace running proper? Spydey HVAC 6 12-16-2011 07:57 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Ducane furnace quit working New Mexico HVAC 3 11-17-2009 09:01 PM
