Old 07-23-2011, 04:22 PM   #1
Why did my Hunter Thermostat blow up? ....twice
We came in the house the other day and smelled an odd burnt smell...burt wires, computer board etc. Turns out it was my hunter auto II temp heat pump thermostat. Therefore neither the compressor nor the blower was responding. So I 'brilliantly' decided to take the exact unit from upstairs (exact same wiring)...they have both been working fine since 2002...wired it correctly and tightly. Turned the fuses back on. Everything was okay and then as soon as i switched it to A/C...it blew up again. .....thoughts?
y-gro-up is offline   Reply With Quote
Old 07-23-2011, 06:12 PM   #2
An old Tradesmen
Short in a component on the A/C circuit.
The Following User Says Thank You to beenthere For This Useful Post:
y-gro-up (07-23-2011)
Old 07-23-2011, 08:49 PM   #3
thanks tomorrow i will venture into the circuit board and have a look. Is this something a decent DIYer can do?
Old 07-23-2011, 08:53 PM   #4
An old Tradesmen
m ay be in the circuit board, or the coil of the outdoor contactor, or in the wires themselves.
Generally, if you have a multimeter, and know how to use it, you can find a short.
Tags
blew up, blown fuse, exploded, short short short, thermostat
Wiring on Hunter Analog Thermostat woomama HVAC 16 03-22-2010 02:52 PM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 02:17 PM
Hunter 44668 Thermostat - Heat won't turn off ToneyRes HVAC 9 10-18-2009 09:50 PM
Problem: Goodman GMNT to Hunter 44155C Thermostat shipupride HVAC 5 10-11-2009 05:36 PM
Hunter Thermostat Problem kohlernm HVAC 1 11-22-2007 10:58 PM
