Why Can't I Get My Air Filter In Without Smooshing It? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-30-2008, 03:15 PM   #1
Rewards Points: 270
Why can't I get my air filter in without smooshing it?
The Trane XR80 calls for a 14x25 but the opening is only 13.5" tall, is this normal? There is no room to angle it in. It is frustrating to mess up my $20 filter or whatever. It seems like the filter holder bracket things are not put in right, but that still doesn't help the fact that the door opening is smaller than the filter. The inside height is exactly 14".
pcampbell is offline   Reply With Quote
Old 05-31-2008, 12:51 PM   #2
I would take a tape measure with me to the store and measure a different brand filter. I've had the same problem from time to time and another brand usually fixes it.
cjett is offline   Reply With Quote
Old 06-05-2008, 09:46 PM   #3
need to buy the right size
ro9beam2002 is offline   Reply With Quote
Old 01-11-2009, 08:48 PM   #4
Rewards Points: 270
Like I said, I measured it, and it's 25x13x1. The manual says 25x14x1 (which is a standard big box store size), but the CABINET opening, is only 13.5". They make custom re-usable filters which are flexible.... would hopefully get into that spot better? Any experience with re-usable filters?
Old 01-11-2009, 11:01 PM   #5
JohnH1's Avatar
It looks like you have a filter rack in the furnace to the right of the filter. Trane makes a adjustable rack that fits in that location. It looks as if someone may have installed it backwards. Look in at the oposit end of the shiny metal rack to see if is open at the back side. if it does turn it around and re measure for a filter that will fit. The rack oridginally came with a perminent washable filter.
Just a side note most filters are smaller by 1/2" so 14 is 13 1/2 etc.
JohnH1 is offline   Reply With Quote
Old 01-14-2009, 01:13 PM   #6
Rewards Points: 270
I took the whole metal thing out. Where my filter is, is a slot for a filter, which is closed on the back side. Seems like where it is supposed to go. The thing to the right of it is seems to be just a frame. The people who put it in did not screw it down so it kept moving and getting all crooked. Still, even with it screwed down, and put in straight, the filter does not fit without getting smooshed. Not exactly a great seal either.
Old 01-14-2009, 02:10 PM   #7
An old Tradesmen
Rewards Points: 6,140
I doubt your duct system is designed to use such a restrictive air filter as that allergen.
Old 01-14-2009, 02:24 PM   #8
Rewards Points: 270
Yeah I just changed it to a cheapo filter.
filter in concord 80 plus furnace hyyx632 HVAC 5 12-12-2008 11:21 PM
fuel leak where filter line meets tank line sonofthetonsured Automotive Repairs 2 04-22-2008 09:11 AM
Furnace minus filter dsal HVAC 16 02-24-2008 01:26 PM
Faucet options for undercounter water filter mdr25 Plumbing 4 03-02-2007 05:56 PM
