Who's The Best At Multi-Split ACs? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-26-2012, 09:39 AM   #1
Rewards Points: 16
Who's the best at Multi-Split ACs?
I love this forum and have received many helpful tips to assist with my DIY projects. Here's my latest...
I am looking to purchase a Multi-Split AC+Heat Pump systen: 5 zones. Looking at 2 wall units and 3 ceiling cassettes.
What's the best out there as far as
1) Manufacturer: LG? Klimaire? Haier? Sanyo? Mitsubishi?
2) Ease of Install/Maintenance: Either DIY or HVAC serviceman (without needing to be a specilaist)
3) Efficiency: Best Heating/Cooling for East USA (New York) weather
Our biggest room is 30' x 15' with cathedral ceilings.
CarlosHRNYC is offline   Reply With Quote
Old 05-26-2012, 02:01 PM   #2
An old Tradesmen
Rewards Points: 7,318
Probably Mitsubishi
The Following User Says Thank You to beenthere For This Useful Post:
CarlosHRNYC (06-01-2012)
Old 05-26-2012, 08:45 PM   #3
Rewards Points: 264
We have had a Mitsu City-Multi installed for 8 years with no problems.
7echo is offline   Reply With Quote
The Following User Says Thank You to 7echo For This Useful Post:
Old 05-26-2012, 09:53 PM   #4
Missouri Bound's Avatar
I take it you can't use central air? No ductwork available?
Do you want it your way or the right way?
Old 05-27-2012, 02:30 AM   #5
REP
Stick with Japanese units and you should be alright.Stay far far away from any made in China .Those are junk and parts and more importantly support is all but nonexhistant.
Sanyo and Mitsubishi are very good units with good back up.
REP is offline   Reply With Quote
Old 05-27-2012, 06:06 AM   #6
Rewards Points: 16
Great leads everyone!
Yes, I have no attic space so... can't do traditional cent air.
Your input is why I keep coming back to this forum. Thank you!
Old 05-27-2012, 07:46 AM   #7
Rewards Points: 258
I have a 12,000 btu Fujitsu split ductless air conditioner. It worked flawlessly for over 4 years but lost refrigerant recently. The heating and cooling contractor said that the refrigerant compression fittings otside typically vibrate loose resulting in loss of refrigerant. This same contractor damaged the connector cover and when I called Fujitsu to see what a new cover would cost, I was advised that the company will not deal with consumers. I can understand this policy as it applies to mechanical parts but a piece of plastic held on with one screw is another story. So, I give the product good reviews for quietness and cooling ability but downrate it for the use of fittings that loosen (maybe they all do) and refusal to deal with consumers, The contractor balked at replacing the cover but has changed his tune after being contacted by the Better Business Bureau.
retired guy 60 is offline   Reply With Quote
The Following User Says Thank You to retired guy 60 For This Useful Post:
CarlosHRNYC (05-27-2012)
Old 05-27-2012, 08:17 AM   #8
Rewards Points: 16
thanks for offering your first hand experience Retired Guy.
Old 05-27-2012, 04:11 PM   #9
Rewards Points: 258
You're welcome. keep in mind that the installation of a ductless split system is not a do it yourself project. I hired an HVAC guy as well as an electrician. It was very costly. I think the Mitsubishi model is rated better than Fujitsu but costs more too. We tried a window unit in the bedroom ($200) at Lowes but my wife could not sleep with the noise. If I have to have the refrigerant replaced every four years at a cost of $160, my Fujitsu AC may end up a costly proposition. The HVAC guy who refilled the Fujitsu said the refrigerant fittings should have been designed to be brazed and then it truly would be a sealed system with no need for refigerant replacement with normal useage.
Old 05-27-2012, 05:41 PM   #10
An old Tradesmen
Flare fittings are common on many small refrigeration systems(coolers and freezers), and all mini splits. Leaks at those joints are seldom. The guy that said its common for them to leak is incorrect. Bad flaring will cause problems. But that is an installation problem, not a manufacturer problem.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
plummen (05-27-2012), retired guy 60 (05-28-2012)
Old 05-27-2012, 10:42 PM   #11
Rewards Points: 616
I agree............. a little oil on the flare before its tightened and it will most likely never leak..........
carmon is offline   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
Split floor joist scottyv81 Building & Construction 6 12-23-2010 02:42 PM
Split Air Returns Earnie HVAC 6 02-06-2010 07:29 AM
Repairing Split in Wood Door? diyintexas Carpentry 4 10-11-2009 01:00 AM
Split 3-phase mdwkailua Electrical 21 04-07-2009 01:55 PM
Ductless split system - advice mikeyd HVAC 9 06-26-2007 05:23 AM
