Whole House Steam Humidifier - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2013, 12:06 PM   #1
Rewards Points: 201
Our home has a pretty old Aprilaire bypass evaporation humidifier installed and I notice it has failed. Rather than fix this old thing, I want to put a new unit in and came across the option of steam.
The existing unit has a large duct that runs from the return side to the failed Aprilaire unit and obviously a fairly large opening cut into the supply duct.
Using a steam humidifier, from what I see, I will only need a small hole. What is my best method to cover up the existing opening? I thought about just making a blanking plate to cover the duct that comes from the return side.
Also, recommendations on brand? I like the Honeywell TrueSteam, but I see a big mix of positive and negative reviews. Looking for some real world feedback here.
Thanks.
phuz is offline   Reply With Quote
Old 12-01-2013, 12:25 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,092
If you can get enough humidity with a bypass then definetly use one. Steam units are very expensive and problematic. I only recommend them for huge houses where a bypass won't keep up. Unless you have a water softener and filter like Honeywell recommends then true steam can be a big problem and that is a big extra cost. Chemistry 101. When you evaporate water then minerals get left behind on the heating element and water level probes etc and create a huge problem. Honeywell makes good DIY friendly bypass units and HDepot has them.
Old 12-01-2013, 12:30 PM   #3
Rewards Points: 201
Thanks for the quick reply. What about the types that are self-powered and do not require the section from the return duct?
Such as the Honeywell HE360?
Old 12-01-2013, 12:36 PM   #4
Hvac Pro
yuri's Avatar
bypass is the most simple and reliable. fan powered needs 120 volts to it and eventually that motor will wear out.
The Following 2 Users Say Thank You to yuri For This Useful Post:
hvactech126 (12-01-2013), phuz (12-02-2013)
Install Steam Humidifier above a-coil - gas furnace MarkMontreal HVAC 1 02-15-2012 01:09 PM
Humidifier with direct water hookup no furnace in the house sueraney HVAC 5 04-10-2011 01:55 PM
Whole house humidifier. Risks speedster1 HVAC 1 01-05-2010 05:24 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
Whole house humidifier jerryh3 HVAC 47 10-25-2008 11:09 PM
