Whole House Humidifier, Without Ductwork? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-19-2012, 08:06 AM   #1
Post
Whole house humidifier, without ductwork?
I'm looking for a whole house humidifier to buy for an elderly man who will not be able to refill the jugs for the portable units.
I'm thinking like of a system similar to freezer ice makers...a water line in and the machine shuts off the water when it's done.
I am wondering if there is a whole house humidifier that is self fed for a house without central heating/cooling. It's a very old house and would cause a lot of trouble/money to be modified for the duct work.
Anyone know of one?
CGHoffman is offline   Reply With Quote
Old 11-19-2012, 11:02 AM   #2
Rewards Points: 484
A few manufatures make a unit that can be mounted in the wall and has a fan in it, a little pricey but should do the trick for him.
My solution before I installed a proper humidifier in our house, was to just take a portable swamp (evaporative) cooler and installed a float in it and ran it off the ice maker line. It was a bit of a crude setup but it worked fine.
The problem with portable humidifiers, is that most of them use a wicking proccess for keeping the pad wet and when you start to get an alkali builup on the pad, it stops wicking. By the design of them, it also makes it hard to try to retrofit a float system to them also.
sammy37 is offline   Reply With Quote
Old 11-22-2012, 12:20 AM   #3
I went with the Aprilaire 350 for my house. It does a great job.
http://www.aprilaire.com/index.php?z...ory=5&item=350
StahlMaster is offline   Reply With Quote
Old 11-22-2012, 08:10 AM   #4
An old Tradesmen
Rewards Points: 6,458
Yep, the 350 and 360 are the ones ou should look at. One installs through the floor, the other through a closet/utility wall. Both need to be fed with hot water.
Humidifier with direct water hookup no furnace in the house sueraney HVAC 5 04-10-2011 01:55 PM
Best Whole House Humidifier Kurt1968 HVAC 1 01-30-2010 09:23 AM
Whole house humidifier. Risks speedster1 HVAC 1 01-05-2010 05:24 PM
Whole House Humidifier Problems ferretwoman HVAC 6 02-23-2009 07:48 AM
Whole house humidifier jerryh3 HVAC 47 10-25-2008 11:09 PM
