Whole House Humidifier Settings - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-07-2013, 06:06 PM   #31
Hvac Pro
yuri's Avatar
Rewards Points: 1,112
the humidistat needs 2 B in the return air duct and B 4 where the moist air from the humidifier enters. if the air from the humidifier hits it then it will be inaccurate.
Old 11-08-2013, 01:09 PM   #32
Rewards Points: 18
Originally Posted by beenthere View Post
The humidistat for the humidifier is probably inaccurate. or in a bad location. Set it to 30% and see what your hygrometer says 6 or so hours later.
You can get humidistats that have an outdoor sensor that will automatically adjust the humidity for you as the outdoor temp varies.
Per the instructions I installed the humidistat on the cold air return duct.
srelliott83 is offline   Reply With Quote
Old 11-08-2013, 01:20 PM   #33
Rewards Points: 18
I do have it mounted on the cold air return duct, but have a question about its placement there. As part of the humidifier installation I ran a flexible duct from the cold air return duct to the humidifier, which is mounted on the supply duct. The humidistat is mounted on the cold air return duct below this flexible duct. Should it be above, or does it not make a difference?
Old 11-08-2013, 01:49 PM   #34
Hvac Pro
yuri's Avatar
what is the brand name and model # as I would like to see the install info. Normally we mount the body of the unit on the cold air duct and the pipe feeding it to the hot air duct. the plastic body of most of those units is not rated for heat and will crack or warp soon. the humidistat is mounted above where the unit attaches to the duct or upstream in the cold duct or on the wall by your thermostat if you can run wire there or have 2 extra wires there.
Old 11-08-2013, 02:11 PM   #35
Rewards Points: 18
It's the Honewell HE240 http://yourhome.honeywell.com/home/P...tive/HE240.htm
Old 11-08-2013, 02:17 PM   #36
An old Tradesmen
Rewards Points: 6,108
Can you post a pic of it. I believe you that its mounted on the return duct. i want to see how.
Old 11-08-2013, 02:24 PM   #37
Hvac Pro
yuri's Avatar
Cool, Honeywell toughened up the plastic on those bodies and allows hot water to be fed to it also. IN the old days it would have to be mounted on the cold duct. post some pics of it and the humidistat
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
Do I need a whole house humidifier? GatorPharm HVAC 1 11-29-2010 06:51 PM
Best Whole House Humidifier Kurt1968 HVAC 1 01-30-2010 09:23 AM
Whole House Humidifier Problems ferretwoman HVAC 6 02-23-2009 07:48 AM
Whole house humidifier jerryh3 HVAC 47 10-25-2008 11:09 PM
