Whole House Humidifier - HVAC - DIY Chatroom Home Improvement Forum
Old 10-17-2008, 07:55 AM   #1
Whole house humidifier
Has anyone here installed a self-contained whole house humidifier? I'm looking between the Aprilaire 360 and the Fedders/Trion 707u. I'm leaning towards the 707u because it only requires a cold water supply and no drain while the 360 needs a hot water supply and a drain. Just looking for opinions if anyone has used either (or a similar type unit).
jerryh3 is offline   Reply With Quote
Old 10-17-2008, 09:23 AM   #2
What climate are you using this for? All seasons or just winter?
dac122 is offline   Reply With Quote
Old 10-17-2008, 09:28 AM   #3
The Aprilaire is an evaporative system so it uses a hot water supply. It has a 6 gph flow rate, so it cold go through a lot of hot water. The Fedders is an atomizer so it only needs cold water. These are both freestanding/through the wall systems. I have hot water baseboard heat so I'm limited on the systems that are out there. These are the only two I have found.
Old 10-17-2008, 11:19 AM   #4
Rewards Points: 1,088
You might want to reconsider the Fedders model, not because it's not a good product, but because Fedders recently filed for bankruptcy protection.
I know because I have a portable humidifier made by Fedders that needs repair and they're not honoring warranties until/unless they get their act together.
handy man88 is offline   Reply With Quote
Old 10-17-2008, 11:31 AM   #5
I saw that. That goes in negative column for the Fedders.
Old 10-17-2008, 04:58 PM   #6
HEY GUYS!
An atomizing humidifier? Sure they work for a while.
But those of you who have them vs. those of you who sell them and install them, why don't you describe the maintenance requirements to us?
hvaclover is offline   Reply With Quote
Old 10-17-2008, 05:15 PM   #7
Originally Posted by hvaclover View Post
HEY GUYS!
You mean the scale, algae, and slime buildup? That's why I was hoping to hear from some people that have actually used them. The installation instructions say to install a good pre-filter, but I wanted to hear real word experiences with either type of system.
Old 10-17-2008, 05:26 PM   #8
Stick with a good bypass drain type humidifier.
Old 10-17-2008, 05:32 PM   #9
Yeah, I know. But that requires a bigger hole in the wall, a hot water supply, and a drain. Plus, it's $90 more. But, you get what you pay for.
Old 10-17-2008, 05:34 PM   #10
There's steam too.
Old 10-17-2008, 05:38 PM   #11
There's steam too.
I haven't seen any stand-alone steam units. That would be my first choice.
Old 10-17-2008, 06:01 PM   #12
An old Tradesmen
Rewards Points: 6,098
Unless your house is real drafty, the Aprilaire shouldn't be running too much.
Might want to see if you can lower your air infiltration more. That will decrease the amount of moisture the humidifier has to add to the house.
Old 10-17-2008, 06:07 PM   #13
I've tightened the house up as much as I could. All new windows and new door seals. But, it is an old house so it's still a little "drafty."
Old 10-19-2008, 08:47 PM   #14
Just using it for winter.
Old 10-20-2008, 11:47 AM   #15
What can I find here?
Winchester's Avatar
Rewards Points: 150
More than likely there is much more that could be done to tighten up your house.
Winchester is offline   Reply With Quote
Tags
humidifier
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Humidifier & Thermostat BigD HVAC 1 12-19-2007 09:04 PM
HVAC humidifier issue rfjm58 HVAC 4 04-12-2007 07:46 PM
Re-siding house jdig Building & Construction 5 04-10-2007 10:15 AM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 03:57 PM
