Whole House Humidifier - HVAC - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 08:00 AM   #1
Rewards Points: 65
whole house humidifier
Have 2400 sq ft 1 floor mfgr'd home. Live in North Country in NY State. Wish to install whole house humidifier. Available for this application? Oh, electric furnace, code compliant?, Thanks for any info.
rpulley825 is offline   Reply With Quote
Old 11-08-2011, 08:22 AM   #2
Rewards Points: 494
Post furnace model # and whether water supply and a drain is in proximity of furnace. Pic of ductwork would help.
diyorpay is offline   Reply With Quote
Old 11-08-2011, 09:02 AM   #3
Rewards Points: 65
miller electric model E3 specifically designed for mfgr'd home. Water overflow not an issue. ducting on RH side of furnace (facing it) @ floor level. Hope this helps, thanks!
Old 11-08-2011, 10:53 AM   #4
Rewards Points: 494
There are many brands and at least 3 types.
Skuttle and Aprilaire are very popular. As long as you have a blower fan, any humidifier will add moisture.
Adding sensors (inside/outside temps etc) will automate vs. manual.
Some have reservoirs and use less water (but water is standing/not turned over). Bypass types use more water. Steam types work the best but are expensive and can clog with hard water mineral deposits.
Query the HVAC site. There are many opinions.
sample of brands:
http://www.appliancefactoryparts.com...ers/index.html
The Following User Says Thank You to diyorpay For This Useful Post:
rpulley825 (11-08-2011)
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
Do I need a whole house humidifier? GatorPharm HVAC 1 11-29-2010 05:51 PM
Best Whole House Humidifier Kurt1968 HVAC 1 01-30-2010 08:23 AM
Whole House Humidifier Problems ferretwoman HVAC 6 02-23-2009 06:48 AM
Whole house humidifier jerryh3 HVAC 47 10-25-2008 10:09 PM
