Whole House Fan Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 08-20-2012, 10:05 PM   #1
I installed an Air Vent whole house fan a few years ago that I got at Lowes, and it seems the motor is shot. Although a GE motor that was made in Mexico, I haven't been able to find a replacement anywhere, Lowes, Graingers or on-line. I did find a Broan #99080214 tonite, that looks like it might fit. The Broan has the same dia case, 5 &5/8, shaft and cw rotation and rpm is similar, 700/500, compared to original of 775/600. Only other option is to get another fan assy. I believe the broan is a better motor as it has ball brgs, compared to bushings in orig. Anybody have experience with this ?
Malibujim is offline   Reply With Quote
Old 08-20-2012, 10:24 PM   #2
Rewards Points: 14,026
When you checked Granger did you check there on line cross referance guide?
Can you take a picture of the ID plate on the motor and post it here?
Should not be that hard to find one if we have the info.
Old 08-20-2012, 10:27 PM   #3
Attic Power vent
You had said that it is an AirVent product. If it is, try www.airvent.com
RJM Build is offline   Reply With Quote
Old 08-21-2012, 12:20 AM   #4
When I went to Graingers, they couldn't cross ref the motor with anything. Biggest problem seemed to be the slow RPM, 775/600. I will try taking a pix and posting it . I might try calling Air Vent tomorrow. Their warranty says to send them the old motor so they can evaluate it, before sending a replacement. I just wanted it repaired now, not in a month or so.
Old 08-21-2012, 12:43 AM   #5
Label on original motor
Old 08-21-2012, 08:46 AM   #6
Rewards Points: 1,668
Try:
http://www.grainger.com/Grainger/oem...998&sst=subset
bob22 is offline   Reply With Quote
Old 08-21-2012, 11:23 AM   #7
Bob22, the 2 motors on that page with less then 1000rpm, #2FGP6 is only 1 sp & #4UY50 is 208-230 V.
Old 08-21-2012, 11:38 AM   #8
I called Air Vent this morning, and although their their website and the warranty info in my installation book says I must return the motor for evaluation first, the girl I spoke with said they'd send me out a replacement motor . I never, ever expected it to be that easy in this day and age !
The Following 2 Users Say Thank You to Malibujim For This Useful Post:
ben's plumbing (09-01-2012), bob22 (08-21-2012)
Old 09-01-2012, 01:17 PM   #9
Just received the replacement motor from air vent and I have 1 question regarding the wiring. They sent a new capacitor with the new motor, and the wires and capacitor are the same as the old motor. I have to wire the new capacitor in, and the wires are both identical brown to the capacitor and the capac. terminals are not marked, so I assume the 2 brn wires could go to either term on the capacitor. Correct ?
Old 09-01-2012, 08:58 PM   #10
fan
I would call their tech support.
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
House Dryer 229 Circuit big elec. motor krrgyy Electrical 9 02-03-2012 01:06 PM
Big water leak under house Puzzles Plumbing 4 04-27-2011 02:50 PM
New fan motor going out? DavidI HVAC 5 06-23-2010 10:38 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
