Whole House Fan Maintenance Or Replace? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 04:03 PM   #1
sheiladderr's Avatar
Question
Whole house Fan Maintenance or replace?
Our house was built in 1982 and has a whole house fan upstairs. The on/off switch is in the garage and we have it taped to the "off" position because the fan has never turned on since we bought the house.
It most definitely needs cleaned, but is there something specific I should look at to see if it will be usable We don't have a/c so we have resorted to floor and table top fans and also have a window a/c unit that we put in the living room window. So having a whole house fan suck the hotness out of the house in the summer would be just lovely!
I just don't know what to look for when I get up in the attic to start looking at it. Or is a whole house fan beyond maintenance and should just be removed and we deal with the hot until we can afford to have a/c installed?
sheiladderr is offline   Reply With Quote
Old 01-16-2012, 04:12 PM   #2
well, yes have it cleaned and have the belts changed (if it uses belts) have the motor and louvers oiled and inspected. whole house fans in the right climate are a God send .......they can reduce humidity and crate a cool breeze, but on a hot stuffy day nothing beats central a/c.
harleyrider is offline   Reply With Quote
The Following User Says Thank You to harleyrider For This Useful Post:
sheiladderr (01-17-2012)
Old 01-16-2012, 06:34 PM   #3
Rewards Points: 410
You might be surprised at how little maintanence it'll take to fire it up.
I put a heavy duty model in my previous house ( all ball bearing ) and ran it for a good 15 yrs.
I also machined up some oilite bronze bearings for a friends fan and its still going about 20 years later.
You should wire a timer into it , Grainger has them.
High Gear is offline   Reply With Quote
The Following User Says Thank You to High Gear For This Useful Post:
Old 01-17-2012, 09:29 AM   #4
Thank you! Can't wait to try it this summer!
Old 01-17-2012, 09:43 AM   #5
Rewards Points: 13,724
There's not all that much to go wrong with them so it's worth a few min to work on it.
The belt is the main thing that's going to make noise, Since it's been sitting for a long time it's developed a set and would make a racket if you tryed running it now. I'd just take it off and go to any automotive type store and they can match it for you.
Before you do take it off have a look at where the bolts are setting in the elongated slots if there set at the max, then someone has put on the wrong sized belt at some point, also look at the way it's setting in the pulley, It should be about even with the top of the pulley.
What often happens is someone has installed the wrong belt. Belts come in differant lengths and widths.
Wrong belt and it's going to squeal on start up and make noise while running.
You may find the fans are covered with greasy dust. Wipe off what you can then spray some orange cleaner on it to cut the grease.
Tags
a/c , whole house fan
Weird wiring in house fdmillion Electrical 13 06-14-2013 06:49 PM
Water seeps/leaks in house from rain jamesm113 Building & Construction 4 04-04-2011 07:41 PM
dealing with exterior slope towards house. organick Building & Construction 26 03-19-2011 02:57 PM
Have to replace 2 water heaters in house we're buying...help! housenewbie Plumbing 9 01-09-2011 11:55 AM
HVAC for c. 1956 House. What would YOU do? David911 HVAC 10 02-08-2010 05:58 PM
