Whole-house Dehumidifier/fresh-air Intake? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-04-2013, 01:48 PM   #16
Talking with a coworker, I realized a much faster/less expensive solution to installing a whole-house dehumidifier: place the dehumidifier itself on the floor of the HVAC closet pictured in the OP, and simply duct the output up the side of the closet to the supply duct.
I checked the NEC, and it appears to require metal conduit in air handling spaces, which would completely invalidate placing the DR65 on the closet floor, since it has screw terminal connections and an IEC input, rather than conduit knockouts. That having been said, I've seen plenty of residential construction (my house included) with NM and thermostat wire in the HVAC closet.
Any thoughts here?
Thanks!
mahohmei is offline   Reply With Quote
Old 07-04-2013, 02:15 PM   #17
An old Tradesmen
Rewards Points: 7,400
It would block off too much of the return for the air handler,.
Old 07-12-2013, 02:28 PM   #18
Rewards Points: 266
You should be aware of this and look for like studies:
Found at building science.com
Conditioning Air in the
Humid South—Creating
Comfort and Controlling
Cost
Research Report - 0214
November-2002
Building Science Corporation
ionized is offline   Reply With Quote
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
basement house inspections/ problems base_build_01 Building & Construction 1 08-01-2011 08:38 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
